CP3 Plumbing
Old Jan 20, 2009 | 12:53 PM
Ace's Avatar
Ace
CP3 Plumbing
I'm getting ready to install a 2um Cat filter on the 2007 between the stock filter and the CP3. I'm pretty sure the big line coming straight out the back is the high pressure line to the rail, but not sure which of the other two smaller two lines is the feed/return. It looks like the one looping over the top and going down into the front connection on the CP3 is the feed line I'll install the filter into.
Anyone care to confirm that? Tks....
Old Jan 20, 2009 | 01:04 PM
hoffdog's Avatar
when i installed my airdog it was the line that comes out on top and curves back towards the engine.
Old Jan 20, 2009 | 02:21 PM
AH64ID's Avatar
If you trace the line from the bottom of the OE canister to the CP3 you will find the line you need to replace to add the filter. Its the one pictured above.
Old Jan 20, 2009 | 02:50 PM
Ace's Avatar
Ace
Yes great, that's what I thought, basically the one closest to the radiator or front of the truck.
Thanks, gents!
Jethro6213
19
Jul 11, 2008 11:59 AM
pullin hard
Mar 18, 2008 03:57 PM
BADBOWTIE
28
Jul 14, 2007 02:36 PM
megacabrule
33
May 10, 2007 01:07 PM
davelinde
Mar 30, 2006 06:39 PM
