Cowl Cracks revisited
Old 01-04-2007, 11:44 AM
Jake R.'s Avatar
Angry Cowl Cracks revisited
I have the problem of many others with water puddles forming inside of the truck. Ive looked and looked but i cannot seem to find anyone that has used a strong form of epoxy or silicone like substance that will seal it up. Could you drill a hole at each end of the crack and load her up with some high powered glue or will that just cause problems or not be strong enough?
Thanks, Jake
Old 01-04-2007, 05:27 PM
ChrisLib's Avatar
I would use the (now discontinued ) factory patch panels with some Fusor adhesive. The OEM`s use this stuff to glue on quarter panels and such, it`s one of those deals where the bonded area is actually stronger than the parent materials. If ya can`t scrounge a set of OE patches I`d try to fab some up.
Old 01-04-2007, 07:38 PM
loch's Avatar
PERMABOND HT20, its the best there is.
http://www.permabond.co.nz/a_HT20.htm
fab a patch apply the ht and then screw or rivot every inch or so. HT20 has an amazing shear factor, and bonds great.
Old 01-04-2007, 09:43 PM
jw216's Avatar
I had my truck painted this summer bought the factory patch and installed while in shop, still have water in floor. Going after a new door gasket now.
Old 01-04-2007, 11:06 PM
loch's Avatar
JW check your cab lights, mine were leaking. It took me forever to figure it out. If you suspect them use a butyl rubber sealant not silicone.
Old 01-05-2007, 08:02 AM
Boatnik's Avatar
IF you have trouble getting the HT-20 try using 3M's 5200 Marine Adhesive. That stuff is strong and water proof. You can get it at any marine discount supply. It comes in small tubes or the ones used in caulking guns. If the surfaces are absolutely clean it will bond tight enough that you will need a razor to seperate the patch from the cowling. It takes 24 hours to set up and a week to cure.
Old 01-05-2007, 10:27 AM
gozapper's Avatar
I used wind shield eurathane on mine.
wrenchmaster
04-20-2009 08:42 PM
Lightweight
02-23-2006 05:45 PM
spunbearing
03-04-2005 08:37 PM
Paws
10-20-2003 11:26 AM
Redleg
01-04-2003 09:16 PM
Quick Reply: Cowl Cracks revisited
