Cowl Crack FAQ Added
Old Oct 13, 2002 | 05:02 PM
Monty's Avatar
Guys, I have just recently entered the parts info needed to repair the cowl cracks. I will be doing mine very soon. <br><br>Cowl Crack Fix FAQ
Old Oct 13, 2002 | 05:30 PM
nascar mark's Avatar
Re:Cowl Crack FAQ Added
Thanks OkieBroncRider,<br>I'll have to check mine to see what kind of shape its in. Any idea about price?<br><br>mark
Old Oct 13, 2002 | 05:41 PM
Monty's Avatar
I believe Dodge sells the repair panels for 50-70 bucks. I will be checking the price tomorrow to make sure. When I do, I will post it.
Old Oct 15, 2002 | 11:09 PM
baron's Avatar
I recently noticed the annoying squeek under my left side dash board area. Is this the &quot;cowl crack&quot;?? Can you expain a little more about what I am looking for??? and where??? What cowl are we talking about??????? thanks baron
Old Oct 16, 2002 | 08:36 AM
admin's Avatar
I've had that for two years, and mine's a 99
Old Oct 17, 2002 | 05:14 PM
Monty's Avatar
Well, I havent had a chance to run by the ******* yet to get the prices on the panels.<br><br>Baron, if you open your door and look between the door jam and the inside of the front fender, you will see the side of the firewall (cowl). Here are some pictures to help you visualize the process.<br><br>The first pic is before the replacement panels are added.
Old Oct 17, 2002 | 05:18 PM
Monty's Avatar
Here is the aftermarket panels in place.
Old Oct 17, 2002 | 05:20 PM
Monty's Avatar
Here is what needs to come off to do the job. Kind of intimidating isnt it. ;D
Old Oct 17, 2002 | 07:47 PM
dan239's Avatar
OBR<br><br>I see you used enough rivets. When I did my 92, I only used the three that Dodge recommends for each side and one side came loose. Anyone about to do this should look at your pictures, and make sure they use plenty of rivets.<br><br>Also on my 3/4 ton 92, I did not have to take the bumper off.<br><br>Dan
Old Oct 17, 2002 | 08:24 PM
Monty's Avatar
Dan, that isnt my truck...I believe that is GeneH's truck. I have yet to do mine.
Old Oct 18, 2002 | 11:04 PM
baron's Avatar
Man.........this is not something I will be doing too soon!!!!!!!! LIke I have to use my truck daily! baron
Old Nov 5, 2002 | 09:16 PM
DieselBuzz's Avatar
How many hours does it take to get down to that!? <br>This fix is not for the faint of heart!<br>Art
Old Nov 10, 2002 | 02:15 PM
dan239's Avatar
[quote author=DieselBuzz link=board=9;threadid=5867;start=0#62691 date=1036552563]<br>How many hours does it take to get down to that!? <br>This fix is not for the faint of heart!<br>Art<br>[/quote]<br><br>I did mine in one day from start to finish. It was a full day. <br><br>The job is not as bad as it looks. Nothing about it is too difficult, as long as you take your time and do each step carefully.<br><br>Be sure you have the proper brackets. When I ordered mine, they kept sending me two for the same side even though they were two different numbers. They finally concluded it was a factory problem of putting the wrong one in the package. I was not able to get both sides and had to make one of them myself [no easy task, I do not recommend it].<br><br>Hope this helps.<br><br>Dan
Old Nov 10, 2002 | 02:40 PM
Monty's Avatar
Dan,<br><br>Did you notice a substantial decrease in cab noise after the fix?
Old Nov 10, 2002 | 09:38 PM
dan239's Avatar
[quote author=OkieBroncRider link=board=9;threadid=5867;start=0#64776 date=1036960823]<br>Dan,<br><br>Did you notice a substantial decrease in cab noise after the fix?<br>[/quote]<br><br>It completely eliminated the poping or rattling sound coming from each end of the dash, until one side came loose, because I did not use enough rivets. Dodge only recommends 3 and I can tell you that is not enough. You should use as many as you can even if it means drilling more holes. The pictures you posted show how many rivets should be used. Some of the brackets have that many holes already in them and some only have three.<br><br>After the one side came loose, it would only rattle in very cold weather.<br><br>Dan
