Couple of Questions?
I was looking at to fix the KDP on my truck and found this.
It this a new timing case? I don't think I could fit the pin cover there.
Also, I was going to check the gears for timing since it was out. But the manual shows an "C" lining up with the "E" on the fuel pump gear.
And double dots to a single dot on the cam and crank gears.
This is what I have.
Is this correct?
Also, I made a tool to rotate the fuel pump.
I need a longer screw in the smaller hole. It was just for a test.
Here it is in use.
I just drilled and tapped some holes for bolts that corresponded with the holes in the pump plate at an 0.820" center to center in a 1/2" peice of keystock. Since I read you guys cut that top section off, you could just redrill some more holes on the plate down lower.
It makes rotating the pump real easy.
I also made a adapter to check the lift of the IP since I was too lazy to look around for a proper one. I am going to make one for a longer dial so I can hopefully install it with the lines in place. Let me know if you would like picks of it.
Also, if the pump is way past timing, would the truck run?
Thanks for your time.
Is this correct?
Here it is in use.
Is this correct?
Is this correct?
Yes the truck would run way advanced or way retarded. Might not run or sound good, but will run.
The raised area around the dowel pin is on the first gen., while the flat area is on the second gen. TST Products makes a 'stepped' tab for first gens. You'll have to specify which tab you need.
Aloha,
Matt
Aloha,
Matt
I had read somewhere that Dodge had made some changes to the timing case to stop that problem and thought mine might have been changed as it didn't look the same.
Glad to have shed some light for ya.Aloha,
Matt
looking at the first pic with the picture of the timing gear, how would you advance the timing? How dificult is it to do this. I currently have my gear case appart and might be interested in attempting this if its easy??
Hummin Cummins
16
Mar 12, 2003 09:48 AM
acoustic_axe
Feb 2, 2003 09:00 AM
