Cooling help for my '99
Old 01-14-2010, 08:46 AM
DPG
DPG's Avatar
I have a 1999 CTD, with larger injectors, and EZ box, 4" exhaust, and a BHAF. I make enough horsepower and torque for my needs, but when pulling my fiver up mountain grades, it tends to heat up. What else can I do to improve engine cooling?
Thanks.
Old 01-14-2010, 08:52 AM
AH64ID's Avatar
What temps are you seeing? It seems pretty normal for the CTD to warm up to about 215-220. Its hot but normal.
Old 01-14-2010, 09:11 AM
DPG
DPG's Avatar
My gauge isn't exact, but pulling out of Denver going west on the interstate the gauge went way past the "high normal" mark to the point where I had to stop. Hot enough under the hood to shut down my EZ.
Old 01-15-2010, 06:58 PM
oobudoo's Avatar
I had overheating issues for a couple of years while pulling my RV up hill. turned out to be dirty radiator (Outside fins) not letting air through. Had it pulled out and cleaned trying to fix an unrelated problem with my A/C not blowing cold air. Didn't fix my A/C problem, but did not overheat this year pulling the RV. Just for info the A/C problem was fixed by the "blend door" repair. Go figure, spent $800 trying to repair the A/C which I repaired for $35 myself. At least the motor doesn't run hot anymore.
Old 01-15-2010, 07:27 PM
DPG
DPG's Avatar
Thanks oobudoo, I'll take a look at my radiator.
Old 01-16-2010, 07:32 PM
oobudoo's Avatar
FWIW I drove this same trip with my RV several years without overheating. When it started heating up 2 years ago, I checked my radiator by squirting hose water from front while running (Fan supposed to pull water through if not plugged - water got through), felt back side for oil gunk from breather tube (Dirty but not gunked), Best way to clean the rad is by removing, degreaser, pressure wash from back side (Careful of bending fins). Hope this helps
sled4fun
03-12-2008 06:56 PM
CattleKev
13
01-09-2006 04:55 PM
bws
06-09-2004 10:37 PM
mopar2ya
04-01-2004 06:42 AM
Quick Reply: Cooling help for my '99
