Cooler flush??
Old 06-03-2008, 12:06 AM
Billm2004's Avatar
Cooler flush??
as some might know, i blew up my TC about 3 weeks ago. well now that i have my newly cleaned tranny, and new converter, whats a good way to clean out the cooler of debris??
im really trying to avoid taking the cooler out, so any ideas to do it while in?
Old 06-03-2008, 12:37 AM
skchevota's Avatar
Most auto stors sell cooler flush kits, or at least they used too. try napa, it is a presherized can of solvant that you blow through the cooler, then you blast it with air to force it all out.
Old 06-03-2008, 03:52 AM
Billm2004's Avatar
i have been trying that with brake cleaner and my air compressor, but it doesnt come out of the other end enough, just drips a little. ill have to see if i can find that cooler flush kit.
Old 06-03-2008, 08:30 AM
Jame's Avatar
I latched onto a used in tank fuel pump that was still good and use it. Just use clean fluid in a bucket and push fluid the opposite direction of normal travel until clean
Old 06-03-2008, 08:52 AM
dzlfarmboy's Avatar
We usually blow it out in reverse direction with compressed air and then spray brake clean through the system and blow out in both directions till all the way clean. On the 48re i believe you can only blow through the way the fluid usually runs, must have a check valve in the lines.
Brett
CACalomino
16
03-22-2010 06:35 PM
Sam Turner2
11-18-2008 10:17 AM
DodgeDiesel61
09-18-2008 10:55 AM
grantx5
01-05-2008 06:56 AM
LFD2037
11-08-2006 09:12 PM
Quick Reply: Cooler flush??
