Cool tool for cutting circles
Old Jun 15, 2007 | 07:11 PM
rbrettctd's Avatar
A welder on our ranch showed us this. Easy way to cut circles with a torch in sheet metal.
What you need:
3/8" all thread rod(any decent size should work)
2-same sized nut.
Washer the right size to fit snuggly around the torch tip-ours was 1/2"
Welding rod for a cradle on the back side
Nail for the pivot
First, find the washer that fits your tip and weld it end to end of the all thread. Then build your cradle. It should come straight off the rod then split to fit tight around the torch body so that it wont slide off. Get the rod sitting level with the rod. After this, test fit the assembley on the torch. Then run your 2 nuts onto the rod. Take the torch close to a sheet of metal and find the length of nail you need to keep the tip the right distance off the metal. Once you cut your nail down, weld it to one nut. The other nut is your jamb nut. Once you have this built, I recommend using rubberbands to help hold the assembley to the torch, since they are easy to take off. Now just adjust your nut to get the radius you need, then suck the other nut down tight to it so it wont come undone. Heres a pic of the finished product, and a nice circle it can cut. Im working on a pretty neat Texas star project that Ill post pics of when done. Tell me what yall think.
Old Jun 15, 2007 | 08:19 PM
new2ctd's Avatar
Outstanding!
Old Jun 15, 2007 | 09:05 PM
fschiola's Avatar
That's a very cool idea! thanks for sharing it with us.
Old Jun 15, 2007 | 10:02 PM
whereswaldo250's Avatar
WOW I like that looks great
Old Jun 15, 2007 | 10:12 PM
yfz450guy's Avatar
and here all these years i have been using a hole saw.
Old Jun 15, 2007 | 10:42 PM
WUnderwood's Avatar
great idea, thanks for sharing
Old Jun 16, 2007 | 09:54 AM
rbrettctd's Avatar
No problem thought that was cool and figured yall would too.
Mkinner
Sep 21, 2010 07:57 PM
Homestead
Dec 22, 2006 05:38 PM
tyssniffen
Mar 21, 2006 05:24 AM
Varmint
Mar 26, 2004 10:40 PM
SBishop
Feb 14, 2004 05:21 PM
