Control arms for 37s
Old 12-22-2008, 04:15 PM
OldSmokey's Avatar
Im thinking about some 37/12.50/18 pro comp xtreme a/ts for my next tires. If I do so I will need some longer control arms made, but how much longer do they need to be? Im just running three inch blocks in the front. I will also be putting on some new wheels but I like the wider look so I want them have as little of back space as I can. Anyone have any input?
Thanks Joel
Old 12-22-2008, 04:19 PM
cquestad's Avatar
4.5 to 5" of lift with 5.5 BS on a 8.5 wheel with a 37x13.5 is as close as you are going to cut it.
I have tuff country CA's....maybe just a 1/4" shorter than those might work with 3".
Old 12-22-2008, 04:50 PM
ZacMan5712's Avatar
top gun customz will make you a set for $240. that's the route i just took, waiting to get them.
Old 12-22-2008, 04:55 PM
D45
D45's Avatar
Just to give you a reference, stock arms are are:
Upper: 16 5/8"
Lower: 18 5/8"
Old 12-22-2008, 06:15 PM
Danderson's Avatar
Carli's are 1/2 " longer. They have two grades of arms.
Old 12-22-2008, 11:22 PM
OldSmokey's Avatar
Thanks guys. I may have to throw some on and see what happens. The wheels I have now are 9 wide with 4.75 BS and they dont rub anywhere with 35s. I bet its gonna be close even with new CAs.
Old 12-23-2008, 10:05 AM
Megaramasaur's Avatar
Call Mike at LazarSmith, I saw the one's he made for his truck and they are sweet.. Not sure if he makes them for the public, need to check out his site, but they definately are nice.
Old 12-23-2008, 11:14 AM
cquestad's Avatar
37x13.5 on 4.75 BS will tear your fenders off unless you have 6-8 inches of lift and NO travel.
Old 12-23-2008, 05:55 PM
OldSmokey's Avatar
Yah I wouldnt put them on my present wheels. I plan on new ones with more bs.
Old 12-24-2008, 10:17 AM
XLR8R's Avatar
I usually go 1/2" longer with leveling kit-range lifts (2-3").
Backspacing is a tradeoff between losing lock-to-lock steering and rubbing the plastic fenderwell & chin fairing.
Old 12-24-2008, 02:41 PM
J.Suplanski's Avatar
Thumbs up control arms
Give Carli Suspension a call, talk to Jesse Baja Mike or Sage 714-532-2798
JWBartel
07-14-2005 09:39 PM
Valv
03-21-2005 01:41 PM
hellotbone
11-21-2003 07:44 AM
hellotbone
08-20-2003 12:51 PM
Quick Reply: Control arms for 37s
