Commander pre and post turbo egt probe install
Hello All,
I down loaded the Quadzilla install instructions and it appears there are two methods for installing the probe, pre and post turbo. What is the difference, because the post install would most likely be the safest method? Do temperatures have that much variance between the two locations.
Pre turbo is the true exhaust temp coming from the cylinders and will allow you to more acurately monitor your max temp to protect the pistons. Both would be nice to see what the turbo is doing, but I think pre is by far the best. You'll have to decide how to protect the turbo from drilling chips. Probably the most sure way is to dicconnect the turbo and block the opening. I left the turbo on and ran the engine on high idle during drilling and tapping, and partially blocked the exhaust. Worked fine but was hot.
Wetspirit
Wetspirit
Polish Rocket
24
01-04-2023 12:44 PM
HorseHauler
15
03-31-2005 02:28 PM
