Codes and NO FUEL...need help please
Old Aug 27, 2005 | 11:34 PM
B.A.Ram's Avatar
Aight I have 3/4 of a tank of fuel. Just got my EZ box back on. I've put 26 miles on it and while I am sitting at the beer store, my fuel guage drops to below zero, the low fuel light comes on. I turn it off and turn it back on and the gauge was still at zero. I know I have fuel. Oh and I checked codes and I got a 1693(companion) and a 0234(I assume is overboost). Any idea why the codes and why the fuel gauge quit working?
Old Aug 27, 2005 | 11:43 PM
Haulin_in_Dixie's Avatar
Probably two seperate things. The fuel gage is a common problem, have to pull the tank or bed and replace it. Forty some dollars if I remember right. The boost code, if it is, I did not reference it, shows up on mine some times, every six months or so. Best to clean the sensors and see if that stops it. Or the sensor could be bad. That is if you don't have a boost leak from a boot or whatnot.
Old Aug 28, 2005 | 12:18 AM
B.A.Ram's Avatar
What boost sensor are you talking about? I will check my boots. What fuel sensor is it? Is it under warranty?
Old Aug 28, 2005 | 08:59 AM
Mopar1973man's Avatar
MAP sensor...
Old Aug 28, 2005 | 10:21 AM
B.A.Ram's Avatar
Oh the map sensor needs to be replaced for the overboost code? Can I still drive it?
Old Aug 28, 2005 | 04:20 PM
high country's Avatar
Re: Codes and NO FUEL...need help please
Ok problem one the code, don't buy a new map sensor if you had the EZ off with the boost elbow still on as that is your problem, the code will go away soon, if you did not have the boost elbow on without the EZ check the plug on the map sensor. problem 2 is most likely at the sender in the tank, tough to get to easy to replace once it is out, my float rotted right off the actuator arm, many have troubles with the contacts not the best part on the truck, when you do replace it do the sender mod (spring and nut to keep contacts touching) before you reinstall it
Old Aug 28, 2005 | 05:42 PM
MadDog01's Avatar
I agree with High country, As far as your codes are concerned, they will go away after 40 warmups or you'll need a scanner like obd2 to erase the codes. I had a loose connection on my EZ where it connected to the map sensor and once I went over 22lb's, two codes were generated, 1693 and 0234. If you drive without the EZ installed you have to watch your boost or remove the boost elbow and reinstall the stock elbow. Good luck.
Gary
Old Aug 28, 2005 | 06:12 PM
B.A.Ram's Avatar
Ok, the 0234 code makes sense because I drove it with the boost elbow in while my EZ went back to Edge. How expensive;what sensor;how hard to replace; and do you guys think it is covered under the warranty since the LP and IP are? Also what sender mod are you talking about high country?
Old Aug 28, 2005 | 07:48 PM
If you drove it with the boost elbow in and the EZ removed, just forget about it. To be sure if it worrys you, go to Autozone and they will read the codes and remove them. If it does not reset, you don't have a problem. All the computer is telling you is that you ran too much boost. The EZ is a boost fooler so that the elbow can be run with higher boost.
Old Aug 28, 2005 | 07:52 PM
B.A.Ram's Avatar
Anyone know the answers to the sensor and warranty questions?
Old Aug 28, 2005 | 08:01 PM
Not sure if you are talking about the tank sender, that would be out of warranty, not an engine part but a body part. The boost sensor is probably ok but if you went in with the elbow in it they sure would not warranty it.
Old Aug 28, 2005 | 08:30 PM
B.A.Ram's Avatar
Yea I am not worried about the boost code. Is it a fault code meaning that it will defuel the engine or is it just there for FYI? How much is the tank sender? I will have to add it to the list of things to do.
Old Aug 29, 2005 | 06:21 PM
B.A.Ram's Avatar
$51 sensor, should be a fun install.
Old Aug 29, 2005 | 06:28 PM
B.A.Ram's Avatar
any info on this procedure?
Old Aug 29, 2005 | 06:43 PM
crobtex's Avatar
I don't know where you are in Dallas, but if you need Cummins parts go here:
http://cummins-sp.com/locations/
