Code P0628
Old 05-30-2011, 08:04 PM
reddually's Avatar
Code P0628
truck will run at times, than die mainly at lower rpms, need to fix it myself and different things tolook for before removing tank
Old 05-30-2011, 08:11 PM
Adaminak's Avatar
Need some more info: Year of truck, transmission, and SO/HO for starters. Any aftermarket add-ons?
Old 05-30-2011, 08:17 PM
reddually's Avatar
sorry, 2003 6 speed manual, 50hp chip
Old 05-30-2011, 08:32 PM
Adaminak's Avatar
OK...first thing to do is completely remove the power adder. If it's a programmer, return back to stock, if it's a box like Edge or MP8 or Diablo, completely remove the box and all wiring and return to stock. If the problem goes away, you can start troubleshooting from there.
Honestly though, P0628 is almost certainly a dead lift pump, and the only way to fix it is remove and replace the old one from the back of the fuel filter assembly, or remove the old one and add an aftermarket pump somewhere along the way. If you don't want to upgrade to the factory in-tank replacement, you can add an AirDog 100 outside the tank and not have to do anything else except remove the old lift pump.
Old 05-30-2011, 08:44 PM
reddually's Avatar
Thanks for your help, I will start from there Bob
Old 06-01-2011, 07:43 PM
"Swole It like ya Stole It"
Big Swole's Avatar
Yes, 0628 is the Lift Pump code.. I get it constantly from having a FASS pump instead of using the factory in tank pump.
If you don't have a aftermarket Lift pump, I'd say yours is going out.
And I want Definately replace it with an Aftermarket Air Dog or FASS with a filter / water separator (2 micron) system... These CR's NEED CLEAN FUEL, or you will be buying injectors soon...
Old 06-01-2011, 07:50 PM
Big Swole's Avatar
And when you use an Air Dog / FASS / or whatever and have to pull the relay from the fuse box, you will Always have the 0628 code like I do..
Raspy
12-22-2016 06:34 PM
johndeere01
17
11-10-2007 11:10 AM
brockstar
02-13-2007 10:07 PM
DirtEater
21
02-06-2007 06:26 PM
973604x4
06-14-2006 11:11 PM
Quick Reply: Code P0628
