code help/running problem
Old 03-31-2007, 04:52 PM
idracingcop's Avatar
Question code help/running problem
I was driving my truck today, and it started to do some funny stuff!! at times it felt almost like a dead pedal but not quite. I limped home and put on my Snap-On scaner and got these codes.
P1488 Auxiliary 5 volt sensor feed is sensed to be below an acceptable limit.
P0122 APPS voltage input below the minimum acceptable voltage.
P0522 Oil Pressure sending unit (sensor) voltage input below the minimum acceptable voltage.
I followed the trouble shooter for these codes and it said to replace the MAP sensor.
My voltage going to all the sensors have the required 5 volts and the grounds look good. I tested at the ECM pin 10 also for the 5 Volts and pin 11 for the sensor ground and those checked fine.
On the Data menu I have a Map voltage of 2.3 Volts running or not, OPS of 100 PSI and 0.0 Volts running or not, APPS of 0% all the time
How would a map sensor cause the other codes?
My Gut reaction is the ECM took a Big Dump!!
Have any of you had any simular issues? Thanks Brent
Red3quarter
09-09-2012 05:25 PM
snowmanx
01-13-2012 06:56 AM
whity97
03-26-2009 07:06 PM
moparsupremist
08-22-2005 12:06 AM
WLDuBard
02-18-2004 07:26 PM
Quick Reply: code help/running problem
