Clicking in Fuse panel/drivers compartment
Old 05-05-2006, 06:31 AM
swordfish's Avatar
2001 2500 w/cummins 5 spd manual transmission
I don't notice it so much in 1 - 4 gears, but when heading down the highway in 5th I can hear a clicking near the fuse panel. It sounds like an electical switch opening and closing. It is not steady either it is random. Has anyone else experienced this or know what it might be. This is my first Diesel so if this is a standard thing just let me know. Thanks
Old 05-05-2006, 07:49 AM
Rauschbo's Avatar
Welcome to DTR -
-if you haven't any unusual electrical "issues", you may have something loose or broken in or behind the fuse panel, have you done a complete feel-around in there?
Old 05-05-2006, 07:53 AM
swordfish's Avatar
No I really havn't dug in yet. I have only had the truck 3 weeks or so. I have cracked open the fuse panel and everything seems to look in order at first glance. I just wasn't sure if there was something there that was normal and I just didn't know it. Anything specific I should look for since it is only at traveling in 5th gear? Thanks
Old 05-06-2006, 04:59 PM
swordfish's Avatar
I checked today to see if I could see anything out of the ordinary. I didn't see anything. If anyone has an idea as to what this might be. I tested it today. I heard it again when it got around operating temp and it happened in 3rd gear as well...not so much when I was coasting but more when going on an even or steeper grade. Any clues?
Old 05-06-2006, 05:19 PM
Silverjay's Avatar
I chased the same thing for several months. No operating issues and never found it. I finally got used to the sound, now I hear it again.....thanks.
Old 05-06-2006, 08:39 PM
Pirate's Avatar
I may be totally off base since I don't know these trucks well. Had something similar in a rental car one time and at night even saw a slight spark. I paid attention and it turned out to be the A/C relay.
Old 05-07-2006, 01:40 PM
J BODY's Avatar
Try applying pressure to the steering wheel (up, down, side to side) when this noise is occuring. Alot of times there is a steering column "click" noise that make your described sound. My 01 does it.
Old 05-08-2006, 11:46 AM
Eskimo's Avatar
x2.. mine makes the same noise, it REALLY sounds like a relay, but it's only prevalent on bumps...
Chalked it up to steering column noise.
Old 05-08-2006, 03:20 PM
Red3quarter's Avatar
I have had that problem on my 02. I found it was doing it when i'd have the radio volume up. I ended up taking the fuse panel cover out and the noise stopped, I put it back it and the noise came back. My fix was putting some thick tape on a few spots inside the cover and the noise it now gone.
matt
turfguy
02-13-2013 03:16 PM
drivesmopars
16
01-09-2011 11:58 AM
bigjohn92
11-25-2010 01:32 PM
Evildiesel
11-18-2005 04:12 PM
Palmetto_kid
01-10-2004 12:23 PM
Quick Reply: Clicking in Fuse panel/drivers compartment
