clanks when put in R or D
Old Nov 30, 2002 | 01:10 PM
bigbaddiesel's Avatar
when i shift into reverse or drive, i get a real bad clunk. I'm pretty sure its from the rear end. the ujoints are all good. ive heard this is not to uncommon. I hate it though. I should take it to a rear end place i guess. Im just afraid of the repair bill. but what can ya do.
Old Nov 30, 2002 | 05:05 PM
Srigs's Avatar
Re:clanks when put in R or D
Have someone put it in drive or reverse with you watching the drive train. See which part moves and makes the noise. My guess would be one of the U joints.
Old Dec 1, 2002 | 08:30 AM
richard's Avatar
First ,check the u-joints.When your looking at the rear joint take notice to how much the shaft rotates,this could indicate some play in the ring and pinion. If so and if you know how to adjust it, find the factory backlash specs,sorry don't remember them off hand, and this should solve it. If you start to get a howl from the rear end while driving,it's usually the ring, pinion, or carrier bearing.
Old Dec 1, 2002 | 06:28 PM
thanks for the info. this will be way cool if this is something i can just fix myself. now im all exited to go see what it does.
barngal6
Jul 5, 2009 06:49 PM
akgoldminer23
Apr 7, 2003 03:48 PM
Haulin_in_Dixie
Mar 13, 2003 10:25 AM
Oct 11, 2002 06:03 PM
