Check out my oil analysis.... 5k on PB 15w-40 CJ-4 (40k on truck)
Old 11-20-2009, 02:58 PM
banana's Avatar
Post Check out my oil analysis.... 5k on PB 15w-40 CJ-4 (40k on truck)
* 5k on oil
* 40k on truck
* 5.9l; manual trans; bone stock...
* always used Valvoline premium blue.... might switch at one point...(trying to since the last 4 oil changes...haha)
* always FLEETGUARD LF16035 - STRATAPORE OIL FILTER
* truck only carries me and dirtbikes and a small trailer occasionally
* Also add opti-lube XPD most fills...
Old 11-20-2009, 03:11 PM
surfram's Avatar
What brand of air filter are you using?
Old 11-20-2009, 03:52 PM
banana's Avatar
FLEETGUARD AF26106
Old 11-20-2009, 03:56 PM
Mocho's Avatar
I don't know much about it just got mine to. I noticed you have 1 silver to, any idea what it might be from or if it's an issue at all?
Old 11-20-2009, 04:25 PM
banana's Avatar
Blackstone labs explanation sheet (came with report):
"Silver: Trace element, some types of bearings."
Old 11-21-2009, 11:44 AM
QSK60's Avatar
I can check to see what the Cummins recommends for the 5.9 once I get back to the shop on Monday. But the sample doesn't look bad at all. Does the analysis company ask for the type of oil used. You can try the analysis company that we use at Cummins. Not sure the price but you can pick it up at our parts dept.
Old 11-21-2009, 01:34 PM
Hvytrkmech's Avatar
Your UOA is excellent, the only thing I would do different is extend service interval to 7,500, then change, resample the oil and possibly extend even further from there. You are waisting you time and money changing it out at 5k. JMO
Old 11-21-2009, 03:17 PM
CD in NM's Avatar
Good report !!
I do a sample every oil change, they all look as good as yours, I change my oil at the 7500 mfr rec point for the VPB.
CD
jgiachino
28
02-23-2009 02:34 PM
greasefire
10-25-2006 12:16 AM
yarddog
10-08-2005 11:46 AM
belfert
10-13-2003 12:37 PM
Ruralmedic
07-29-2003 12:03 PM
Quick Reply: Check out my oil analysis.... 5k on PB 15w-40 CJ-4 (40k on truck)
