Check Engine light with quad xzt
Old 09-09-2007, 09:28 PM
dodgintrouble's Avatar
I was cruising down the highway yesterday at what we'll call a good clip and I heard the chime from the dash with the check engine light on. Truck ran fine for another 50 miles to my destination. When I was leaving today the light was still on so I shut it down and pulled off the box putting on the bypass plug. The light was still on so I drove for 40 miles with it on and then shut the truck down and put the xzt back on. Light is still on any suggestions?
-Eric
Old 09-09-2007, 09:49 PM
2003Ram's Avatar
Check for codes using the key on method and let us know what it is. I still get codes with mine on occasion as well, usually when towing. The CEL will go away after a number of starts.
Old 09-10-2007, 05:35 AM
How do I do that?
Old 09-10-2007, 06:11 AM
05HDRAM's Avatar
Turn the key from off to on 3 times (without starting). On the 3rd time, leave it on. It will cycle through any codes you have and display "done" when complete.
Old 09-10-2007, 10:28 AM
dodgezilla04's Avatar
if the problem that set the light(could have just been a nuisance light, or a small glitch) is not still causing a fault code, the light will go away after several startup/heat up/cool down cycles. take a few days.
Snopczynski
15
02-25-2008 02:12 PM
choppers555
10-16-2007 12:29 PM
blaster668
08-26-2007 01:04 AM
H8GAS
22
02-15-2007 09:40 AM
BLACKDODOGE
01-03-2006 01:24 AM
Quick Reply: Check Engine light with quad xzt
