Changed Intercooler Boots Last Night and ...
Old Aug 29, 2007 | 08:37 AM
J7 Diesel's Avatar
Question Changed Intercooler Boots Last Night and ...
Holy bajeevas, what a pain in the neck on the 24 valves, do yall know of any easier way to install these? The lower boot on the passenger side is a pain in the EDIT. Starting to do quite a bit of the boot swaps and looking for advice on a easier way, or less of a headache anyway. Thanks
Old Aug 29, 2007 | 09:41 AM
thellums's Avatar
Mine took alot of hollerin' and cussin' to help it on, but I think it helped some. I also tried pullin off the whole piping to the intercooler, installed the lower boot while it was off, then installed to i/c.
Old Aug 29, 2007 | 09:46 AM
J7 Diesel's Avatar
Same outlook here done the same but didnt throw anything, thats a miracle. I had the whole tube and everything out, put the one on bottom and then the turbo side, till a big hassle.
Old Aug 29, 2007 | 09:56 AM
J Double's Avatar
One word....HAIRSPRAY. The boots should slip right over the flanges with very little cussing involved.
Old Aug 29, 2007 | 02:25 PM
johnh's Avatar
don't have any hair spray. would under arm deoderant work?
Old Aug 29, 2007 | 03:23 PM
J7 Diesel's Avatar
This is too much for me to hear! Whats next shaving cream
Old Aug 29, 2007 | 03:26 PM
AggieJustin's Avatar
No, just spray some perfume and talk nice to it
Old Aug 29, 2007 | 03:35 PM
Tocapet's Avatar
If I was to try something like that, my truck would SLAP that perfume bottle right out of my hand, KICK me over backwards and REFUSE to start for 3 hours and 45 minutes.
Old Aug 29, 2007 | 03:38 PM
J7 Diesel's Avatar
That or not get talked to for a week
Old Aug 29, 2007 | 03:39 PM
AlpineRAM's Avatar
If you do aftermarket boots some do suggest boiling them in water to soften them.
Either hairspray or bicycle tube repair glue worked really nice for me.Both will help the boot to hold on the IC or tubing after mounting it. With the tire repair stuff it can be a (insert choice profanity) to remove them. But if prepped right it holds old stockers up to 45 psi for more than a year.
HTH
AlpineRAM
Old Aug 29, 2007 | 09:50 PM
BigBadMegaCab's Avatar
What does this do for the truck anyway I new to the 24 valve
Old Aug 29, 2007 | 09:52 PM
J7 Diesel's Avatar
If you have alot of boost the factory boots are not rated for it. the silicone boots are rated at 110 or 125 psi
Old Aug 29, 2007 | 10:59 PM
Carp's Avatar
My stock boots would pop off with the hy35 pushing a mere 18 pounds. I worked from under the bumper and over the rad support with the turbo connector off. It's all in how you hold your mouth. I said darn once or twice too.
Old Aug 30, 2007 | 04:54 PM
J Lent's Avatar
I've installed a few sets with no trouble at all. The way that I do it is take the old boots off & install new boots using hairspray, but don't tighten them. Then loosen the elbow on the bottom of the turbo & turn it & the intercooler piping until everything lines up perfect. After I am sure that everything is aligned correctly..I tighten the clamps on the upper boot. Then the upper clamp on the lower 45* boot making sure that nothing moves. I then use a bar & hold pressure on the intercooler pipe [lightly] as I tighten the bottom clamp. I pry against the sway bar. Then tighten the elbow on the turbo.
1STGENFARMBOY
Apr 5, 2010 12:25 PM
mullishacrew
Oct 30, 2008 09:29 PM
DNRCustoms
Sep 5, 2008 05:26 PM
06dodge
18
Jun 4, 2007 12:24 PM
eichhoma
Apr 1, 2007 10:35 PM
