Change Front hubs 2WD
Old 09-19-2009, 10:28 AM
TXOVAL's Avatar
Has anyone changed their front wheel hubs yet? IF so what is involved? It looks to me like they have to be pressed out...
Old 09-19-2009, 01:04 PM
MikeyB's Avatar
I haven't done it but it's looks pretty simple. It's a unitized assembly so the hub comes out as one piece. The mounting bolts are on the backside of the steering knuckle.
MikeyB
Old 09-19-2009, 06:05 PM
ScienceOfSpeed's Avatar
i did it and it is so easy. remove the brake rotor and caliper. after that it is 3 bolts on the reverse side of the hub going through the spindle. i cant remember what size the bolts are, dont hold me to this i think they are 15mm. remove the 3 bolts and unplug the abs sensor and it comes out. pretty strait foward. a little tip, when you are installing the new hubs, clean the bolts making sure there is no rust and put some anti-seize on the bolt threads and reinstall. hope that helps ya
Old 09-19-2009, 06:17 PM
pdogg's Avatar
pretty sure it's 18mm... you need a fairly stout long breaker bar to get those bolts off..
Old 09-20-2009, 09:40 AM
TXOVAL's Avatar
Thanks guys, I looked at it yesterday and saw the 3 bolts. I went and bought the new assembly and will have it in today.
When I first looked at it, I thought that maybe it was pressed into the spindle, I'm glad that's not the case. My biggest complaint is how much the part costs...$382 plus tax! Well at least I'll save the $250 labor that Dodge wanted.
Old 09-20-2009, 12:19 PM
i did both of mine and it was funny, the 2wd hubs at the Dodge *********** i went to were more exspensive than the 4x4 hubs. i wish we had the old school hubs that we could rebuild ourselves versus these stupid sealed bearing units. another one of Dodge's ingenus ideas
Old 09-21-2009, 02:22 PM
want2beyounger's Avatar
TXOVAL: let us know if this fixes the humming noise you reported in another thread
Old 09-23-2009, 11:05 AM
dezeldog's Avatar
I paid around $270 about a yr. ago from 123 autoparts and it is a timken unit with a life time warranty. Hope this helps
Jim
Puke
08-15-2011 07:32 PM
91oldranchtruck
01-31-2011 09:45 AM
Bobcat698
04-01-2007 10:26 PM
swabjockey
10-18-2005 08:00 AM
Quick Reply: Change Front hubs 2WD
