Cb
Old Apr 8, 2008 | 02:21 PM
Ezra's Avatar
Cb
Well I got my cb in here are some pic's
Old Apr 8, 2008 | 02:49 PM
Mattster's Avatar
Looks really nice man. Wish my truck was that clean.
Old Apr 8, 2008 | 03:30 PM
Ezra's Avatar
Thanks Man.
Old Apr 8, 2008 | 03:40 PM
Alwaysworking's Avatar
alwaysonDTR
looks good i like the brake peddle, shiney, but at least you still have the rubber cover.
Old Apr 8, 2008 | 04:03 PM
whereswaldo250's Avatar
How did you run the cables through the cab? Also did you use 2 seperate calbles of a Y cable? You have guts drilling into the dash
Nice clean truck
Old Apr 8, 2008 | 04:16 PM
Ezra's Avatar
Thanks,guy's.Yeah I cant get that brake pedal cover to go back on....I just ran the cable under the cab up through the engine bay and through the grommet where the other wires go through into the cab.The antennas I bought ame with the cable that had a y cable at the antenna end.Hey no gut's no glory
Old Apr 8, 2008 | 08:09 PM
haloman's Avatar
Thats where I mounted the cb in my first gen. Its a good spot.
Old Apr 8, 2008 | 08:21 PM
92GhostRyder's Avatar
Your antennas
Just a quick suggestion you can take it or leave it im really really big into CB equipment and so forth and am good buddies with the local tech that has been doing it for 30 years or so. I would reccomend running a magnet mount wilson 1000 or wilson 5000 if i were you. Running cophased or "Dual" antennas on a truck the size that ours are doesnt quite work. Reason being is that for cophased antennas to not interfere with one another they have to be about 8 feet apart or so. plus the fact you have so much antenna hidden behind the cab with the radiation pattern figured it it really really limits your forward RF and TX as well as hampers your over all performance. Just a suggestion any questions let me know.
Old Apr 8, 2008 | 09:28 PM
stackx2's Avatar
the two antennas look cool though i put mine like that
Old Apr 8, 2008 | 09:36 PM
Bogie's Avatar
My CB is mounted further to the pass side under the dash & the ant is on the front bed rail. I like the dual box mount Idea thou.
Old Apr 8, 2008 | 09:46 PM
Jason Foster's Avatar
92ghostryder,
Got any ideas where to mount a Cobra 29LTD in a 2005 Ram with the 6 speed?
Old Apr 8, 2008 | 09:51 PM
Sorry, wrong forum.
Old Apr 9, 2008 | 08:51 AM
wmiller's Avatar
i've got dual antennas hook up the saem way on my truck. I had the same concern when i hooked them up but after testing i get much more swing with 2 rather than 1
Old Apr 9, 2008 | 10:12 AM
Ezra's Avatar
Hey thanks for the good info ghostryder.could I pick one up at a truck stop?
Old Apr 9, 2008 | 11:31 AM
Antenna
No i dont think you can get a wilson at a truck stop. To tell the truth most antennas at a truckstop are ok but not great. You can find em on craigs list all over or if you can find a cb radio shop near you I'm sure they could order one for you. You could also check thier website because i do believe they will ship them too you. If not check Ebay. a brand new one should run 80bux or so with everything absolutely ready to go. http://www.wilsonantenna.com/ Thats thier web url check out the site. I will also tell you when you get a new antenna you have to either get a shop to check your SWR's or you can get an SWR meter and do it yourself. They meters are fairly reasonable at radioshack. This is part of wilsons site as well its a pretty simple guide to help you check your SWRs http://www.wilsonantenna.com/tsswrg.htm. This guides steps will be usefull on all antennas other than wilson. I agree the dual antenna look, looks cool, but do you want your radio to work well? basically just ask yourself if you just want it to look cool more or work good. Also dont let some folks fool ya, a company K40 sells similar looking magnet mount antennas to wilsons but they are "NOWHERE" near the quality. Just trust me, if you get a good antenna you will enjoy your CB much better. If you get a cheap one and dont set your SWR's you can blow a final, or a trasistor. Thats gonna make you hear some but not be able to be heard or put out signal. AKA NOT GOOD LOL. any more questions just let me know. I enjoy helpin fellow CBers get setup and talkin.
