can't get defrost to come on
Old 11-18-2010, 12:08 AM
RJC
RJC's Avatar
I have a 1993 dually W 350 and I can get the defrost to switch over. I have heat and air through vents but can get it to switch over to defrost. Heading out on a trip this weekend and can sure use some help.
Old 11-18-2010, 12:12 AM
ofcmarc's Avatar
Start checking vacuum lines from the heater control to the mode doors .
Old 11-18-2010, 11:11 AM
Unless it's untaxed, then it's red.
#2isgreen's Avatar
Is it possible for one of the vac diaphrams that move the door linkedge rods to go bad?
Old 11-18-2010, 01:27 PM
maybe368's Avatar
In 2 words, Of course!!! It is easy to check them, just put any vacuum pump on it and see if it moves...Mark
Old 11-18-2010, 01:34 PM
archer's Avatar
My 2002 started out like that then lost all control to vents, only had the defrost, was still hot though, and what it ended up being was a hole in a rubber plug on the main vacum line at the fire wall under the hood. It was located about where the drivers side wiper blade is, good luck
Old 11-18-2010, 09:51 PM
#2isgreen's Avatar
thanks
Old 11-21-2010, 03:47 PM
big hose's Avatar
mine did the same thing or still does the control by the gas pedal is the one that runs the def. mine sticks you can reach your finger in one of the holes by the gas pedal and push it
Old 11-21-2010, 05:11 PM
#2isgreen's Avatar
Any hints on where I can find new controls?
Old 11-21-2010, 05:45 PM
maybe368's Avatar
I just did a search and it appears that there are no generics around. I would think possibly a dealer and try a crossover manual, because I bet they used the same or similar in many vehicles. Good luck Mark
Old 11-21-2010, 06:15 PM
maybe368's Avatar
Dodge still has them for the 94 and later. Here is a pic. look at #s 5,9, and 10. I bet you can make 1 of them work...Mark
Old 11-21-2010, 08:16 PM
#2isgreen's Avatar
Thank You. Thats a HUGE help!!
I figured out two things, first, my "outside air" door is positioned so i can only get air from the cab.
Second: if i open the glove box there's a control rod, with the truck running, i can grab that rod and pull it towards the passenger side of the truck and it pops the control door by the trans hump and sends air to the windshield!!
so I'm thinking i just need more vac. or make better use of the vac i have. any ideas how to seal the little rubber slide on connectors to the control diaphram things? maybe some liquid teflon goo?
Old 11-22-2010, 04:34 PM
furious70's Avatar
When we took mine apart to fix the evap the result was the lever for one of the controls doesn't go the last 1/8", I have my glove box off and have to yank it closed. Sucks, but I don't drive it enough to tear it all back apart to try to fix it.
redsealdodge
31
12-07-2007 05:22 PM
Quick Reply: can't get defrost to come on
