CAMSHAFT
Old Nov 6, 2002 | 06:28 PM
1ST GEN.'s Avatar
CAMSHAFT
I HAVE A 97 215 HP TRUCK THAT I PLAN ON PUTTING IN 370 INJECTORS A PDR HX 40 191 DELIVERY AND A # 10 TORQUE LATE SLIDE FORWARD WILL I NEED A DIFFERENT CAM TO KEEP EGT S TO A REASONABLE LEVEL OR WILL THEY BE OK IF I KEEP IT OUT OF THE FLOOR
Old Nov 6, 2002 | 06:46 PM
Don M's Avatar
DTR Advertiser
Re:CAMSHAFT
IMO that year engine responds well to porting of the cylinder head first. Cam second.<br><br>Don~
Old Nov 7, 2002 | 07:23 PM
TxDieselKid's Avatar
Re:CAMSHAFT
If you got the $$$$, why not!!!!
Old Nov 7, 2002 | 10:39 PM
Sled Puller's Avatar
Re:CAMSHAFT
I ran a tuned pump, 191 DV, 370 injectors, 35/16,, #5 or no plate, 4000gov kit, 16 degrees timing for along time.<br><br>Yes, you can bury the pyro.<br>Yes, you can control them with your foot.<br>1/4 mile runs or sled pulls will never melt that engine down at your fueling level.<br><br>Your posts sound like you are ready to rock, get another engine and start from the ground up, when you finish, you will be bored with your setup you want now, it will be a nice transition over to the dark side!
SmokinFive9 4x4
Nov 3, 2004 12:07 AM
drawson
May 4, 2004 12:03 AM
hustler
Mar 31, 2004 08:07 AM
al*gray
Mar 18, 2004 07:57 PM
thumper 549
Jul 27, 2003 08:34 PM
