"Burping the ISB"
Old 03-30-2007, 02:29 PM
jturuk's Avatar
"Burping the ISB"
Something that I have been wondering about for quite some time
I beleive some engine cooling systems can become air locked after replacing the thermostat and refilling with coolant and I have heard of people prying open the thermostat a bit and inserting an asperin before installation to allow coolant to fill the area above the thermostat I presume and prevent this problem. I beleive that this proceedure is refered to as "Burping the engine". I'm thinking that being that I have never seen a post regarding this problem on this board that the ISB must be immune to it?
Thanks in advance for any clarification
John
Old 03-30-2007, 02:50 PM
CSAGrey1's Avatar
I haven't had to do mine yet but the aspirin trick does work on other rigs.
Drilling a small hole works too.
Old 03-30-2007, 06:51 PM
Homestead's Avatar
Someone can correct me on this, but the Cummins have a "jiggle" pin that allows this trapped air to escape.
I have replaced or have had my thermostat out for whatever reason and have never had a trapped air problem, just refill what was drained and go.
Jeff
Old 03-30-2007, 07:02 PM
Valv's Avatar
I just replaced radiator on mine, I refilled it and have no problem. Temp marks fine and motor is just right.
These motors are Cummins guys, there's a reason why they are famous for being good.
These are no LLYs, LBZs or Powerjokes, our motors are studied to have industrial usage, not just in a pickup. Have you seen a Duramax in a powerplant generator ? Or in an escavator ?
Guess what...you ain't !!!!!!!
janb
12-07-2007 02:48 PM
dieselfuelonly
01-26-2007 11:11 PM
possum
05-24-2005 11:30 AM
92DIESEL
11-03-2004 07:43 AM
4WDXPRT
09-08-2004 06:43 PM
Quick Reply: "Burping the ISB"
