Braking shake
Old Oct 15, 2012 | 03:58 PM
woodsRIDER92's Avatar
Unhappy Braking shake
Hey iv got a 97 12v 4x4 that shakes medium braking, it seems like its coming from the rear but i put new drums on the rear and checked the front brakes and they aren't warped, .001" on the passenger side and .003" on driver side. i also checked the drive shaft slip joint if it were seized but it wasn't and i added a bit more grease. I also put on the upgraded bd trac-bar.
And now i have no clue what to check next.
Any ideas are much appreciated.
Old Oct 15, 2012 | 04:45 PM
BigIron70's Avatar
Cummins Guru
I usually check them on a road test, at low speeds just apply parking brake slowly until truck starts to slow down. Shouldn't have any shudder as you slow down. If you do then drums are out of round.
Old Oct 15, 2012 | 06:18 PM
thanks for that ill check that asap
Old Oct 15, 2012 | 07:25 PM
whiskers's Avatar
A lot of times the sway bar link bushings will cause that exact symtom. If you can't find an obvious brake problem check for worn bushings. The shudder feels the same as a warped rotor.
Old Oct 18, 2012 | 12:19 AM
Yea my drums are fine no shudder. whiskers would you say the rear bushings? i know the balljoint on the sway bar in the rear has a bit of play in it
Old Oct 22, 2012 | 10:50 AM
could anyone explain how the sway bar could cause this symptom?
Old Oct 22, 2012 | 08:18 PM
whiskers's Avatar
Don't have a clue why but they do. Chased mine for weeks until I finally asked my son who works on these daily about it. He told me the front sway bar bushings were the cause. Hated to admit it but he was right. No more shudder. Of course I changed every component in the entire front end before I changed them ! And if that joint in the rear has feelable play, I'd change it.
Old Oct 23, 2012 | 01:06 PM
thanks alot whiskers
97catintenn
Apr 3, 2012 08:15 PM
s.squared-39
May 29, 2008 11:07 AM
Need95-00CTD
May 11, 2007 11:51 AM
ric o'shea
Mar 24, 2007 10:50 PM
antknee
Jul 3, 2003 01:06 PM
