Brake ABS sensor problem?
Old Jul 7, 2004 | 07:55 PM
Rattlerattle's Avatar
Howdy,
The ABS and parking brake light come on intermittently, stays on for a couple of seconds and then goes out. The braking is normal. The lights come on when the driving and the service brake or park brake are not engaged. 4 wheel ABS truck.
Any suggestions on where to start looking?
Thanks.
Old Jul 7, 2004 | 08:08 PM
mishkaya's Avatar
As I have found out from experience, check the connections at the speed sensors. Withe a bad connection you will experience this type of thing. I actually had a speed sensor go bad on me once. If there is a problem with the sensor it will not affect braking in any way, just the trouble light.
Mishkaya
Old Jul 8, 2004 | 05:11 PM
Moose10's Avatar
Do a search for ABS. There have been numerous posts about this. Like Mishkaya said it is (usually) the ABS speed sensor on the rearend being dirty/wet/corroded inside the rearend or outside. Mine does the same exact thing every now and then. I've unplugged it, removed the sensor from the housing, cleaned it and the lights stay out for some time.
Old Jul 8, 2004 | 06:38 PM
Thanks for the info.
Old Jul 8, 2004 | 10:18 PM
Scubasteve's Avatar
Check the ABS sensor on the rear differential as they do fail more so than than the front ones.
It is located right on the top of the rear diff.
Jason
Old Jul 8, 2004 | 11:27 PM
Jim Klidy's Avatar
My 99 did the same thing last week just replaced the speed sensor in the diff, cost 34.00 fixed the problem.
Old Jul 9, 2004 | 12:30 PM
Straight6Jeff's Avatar
Mine did the same thing. Ended up needing the two front sensors also. Much better now not haivng the Brake/ABS strobe on the dash
fitzydog
21
Oct 11, 2017 12:09 PM
BigBore050
Mar 9, 2010 11:46 PM
mr T
Feb 24, 2007 06:42 AM
Gear Poet
Oct 18, 2005 02:30 PM
