Bouncing ride on the Hwy in 03 Ram
Quick question. I have a 03 4x4 longbed 4dr CTD. When I drive on the slated highways in L.A. My truck bounces like crazy. I think the problem is that the wheel base is the exact same distance apart as the Fwy slates. Is there anything to lesson the bounce?<br><br>Thanks
Guest
Posts: n/a
Re:Bouncing ride on the Hwy in 03 Ram
I think you're right - it's a "wheelbase thing" - my quad cab '02 does that much worse than my '91 standard cab did, even tho' the suspension on the '91 was lots stiffer - about all you can do is experiment with tire pressure, and maybe different shocks...
[quote author=chrismez link=board=11;threadid=17034;start=0#159482 date=1058125253]<br>Is there anything to lesson the bounce?[/quote]<br>'bout a thousand pounds in back.....
Tire pressure is normal. I love the truck besides the bounce and having to deal with Califonia 235 H.P. 465TG Motor. So far i put a 4' exhaust system and a magnum Force AFI air filter system on it. Better power without the Cat coverter but only average about 16mpg????? I think LA traffic has a lot to do with that. I thought about new shocks but I don't think that will help much. Thanks
Shocks may help, there is a difference between bounce and rough. If there is bounce the shocks will help. Tie a couple of hundred pounds all the way at the rear of the bed and that will help the most.
I installed Rancho 9000's on mine and it made a difference. Run them empty on a 3 setting in front and a 2 in back.
What are the part numbers for the Rancho 9000's? I have called a couple of parts stores and they advise me that they don't have any ranchos for the 03. They also told me that the 03 suspension is different than 94-02 so shocks for those years will not fit the 03.<br><br>??????????????????
When I first wanted Rancho's for my truck I was told that they did not have any for the '03's. Tried again a month later and they checked again and said that shocks from a 94-98 Dodge and a 99-01 Chevy were the same. So I bought 99197 and 99269 shocks and so far they seem to work just fine. There is about a half inch difference in travel compared to the OEM shocks but I can't feel it.
[quote author=chrismez link=board=11;threadid=17034;start=0#159906 date=1058231946]
+Any sugestions on the type of shock I should use?
[/quote]
I agree with Mexstan. The Rancho 9000's are the way to go. When I vistied my in-laws in LA, I hated the rough highways down there >
. I decided to soften the settings one day and made a heck of a difference. Didn't get rid of it totaly due to the stiff springs but made it a lot better.
[/quote]
There's a pair of Rancho RS9000x, part # RS99197, front shocks on eBay right now. Brand New. No reserve. Looks like a good deal.<br><br>Click here to see Rancho shocks on eBay
jaconst
May 22, 2004 04:54 PM
chrismez
39
May 20, 2004 12:19 PM
<br>How is your tire pressure? Shocks? Any adjustments made?
