View Poll Results: Does an 03 need a boost fooler with a Power Puck?
Yes, you need a BF
13
39.39%
No, you do not need a BF
6.06%
I really have not idea but wanted to vote anyway!!!
18
54.55%
Voters: 33. You may not vote on this poll
Boost Fooler or No Boost Fooler?
this is for a 03 CTD HO 3500 with the power puck and a boost elbow only.....i have gotten so many different answers to this question when i asked that I am posting a poll. Do you really need one or not!
hopefully this will clear the air!
There like 20$ and 10 min of wiring just get it.
Jeremy at quad told me that most boxes do boost fooling these days. Heck he said that the MP-8 does BF. Seemed surprising to me. I have a gauge and he said if its gettin 39-43 psi of boost on your gauge your getting boost fooling. Dont know if that helps. it did me.
OK, 03-04 trucks are 100% completely different than 04.5-07 trucks. I know they look the same and sound the same but, they are NOT the same.
The 03-04 trucks have a different turbo and they cannot handle what the 600 trucks can.
You need a boost fooler if you are going to run an elbow. I would bet $1 you already have overboost codes in your truck right now. When the truck cuts fueling back because of it, its not like 1/2 power is gone, it just scales fueling back a lot at those levels. On a dyno you can see it a lot and on the street a little.
I was making right around 50psi before the fooler I was pulling my boat and went to pass a mobil home being transported when I pulled out and got on the side of it one of the lanes ended and I had someone coming quick so I mashed the pedal in 5th and got to 2900 rpm's when the engine started to seize up then shifted to 6th and pulled through. I had the boost fooler put on it no longer will do this and I make a little more boost
I cant imagine it doing better than it already does........ WHOOOOO!!!!!!!
