Blower Motor Sounds Wierd
Old 10-21-2006, 02:52 PM
B.Law's Avatar
Just started today for some reason, in position 3 and especially in position 4 the highest setting it sounds like you are rinding in a turbo prop commuter plane. I used it yesterday with no problems, then this morning it just starting sounding weird, exactly like a prop plane, somewhat of a fluttering roar if that makes any sence. Anyone have any ideas of what it could be? All I have tried is hitting it, unfortunetly that did fix it.
Old 10-21-2006, 02:54 PM
Geico266's Avatar
Pull the motor out and see what's going on. Pretty easy to remove. 3 screws & unplug.
Old 10-21-2006, 03:44 PM
B.Law's Avatar
Wow that was easy to remove. When I first gave it a once over, I didn't realize that it came out that easy. Anyway, apparently it had sucked a napkin in there, that's what was causing all the ruckus. All is well once again till the next trivial problem. Now I guess I see why what's his face is moving over to the Ford forums...
Old 10-23-2006, 08:31 PM
Geico266's Avatar
There ya go! The ol napkin in the squirrel cage trick. Have not heard of that one before.
Old 10-23-2006, 10:29 PM
Greenhornet1986's Avatar
Dang, mine started doing the same thing the other day, guess I need to pull it out and check for something stuck in it.
Old 10-23-2006, 10:56 PM
socal 610's Avatar
my truck did the same thing yesterday but after I shut her down the next run of the ac was quiet
Old 10-27-2006, 09:15 AM
NoChrome's Avatar
Mine did that and I found a airflow door in the fan.
Jim Lane
04-05-2020 06:03 AM
bngcustoms
19
06-14-2009 01:08 PM
Lurch519
07-25-2008 11:51 PM
narced_1
12-15-2007 07:52 PM
Copenhagenjunkie
06-01-2003 04:20 PM
Quick Reply: Blower Motor Sounds Wierd
