blowed gasket
Old 03-23-2009, 08:52 PM
cabtruck's Avatar
blowed gasket
i have a 95 12 valve with a 300 hp bd diesel pump and 40 or 45 hp injectors i have blown the lifter cover gasket out what can make that happen
Old 03-23-2009, 09:15 PM
dieselrob's Avatar
Excessive pressure in the crankcase. See if your breater tube is blocked up or kinked thats the easiet. Only other 2 problems id think is a turbo seal putting pressure in in the oil return line or bad rings on a piston.
Old 03-24-2009, 01:04 PM
kawi600's Avatar
Id check your breather as well as the vacuum pump seals. Make sure its not pressurizing the crankcase.
Do you see a lot of oil mist or smoke coming out of that breather tube? Theres a test in the cummins FSM that can verify its within spec. Gives you a good idea of the condition of the rings.
Old 03-24-2009, 08:03 PM
cabtruck's Avatar
what should the compression be i think i nead to check it
Old 03-24-2009, 08:57 PM
Dmaxcrusher's Avatar
How much is to much oil mist coming out the breater tube? And my vacuum pump seal is bad. Could this be causeing it ??
Old 03-25-2009, 09:19 AM
kawi600's Avatar
Oh yeah.. It will pressurize the case and cause damage. You should be seeing ~28inHG on the vacuum lines.
This would be the place to go:
http://www.fixinrams.com/id21.html
I bought the seal kit and did my own pump real easy.
Just be careful not to strip the threads on the oil plumbing to the pump. Its the braided line that goes to the bottom.
Also, youll want to buy a bunch of 3/8" socket extensions, universals and crows feet to get some of the nuts off in there.
Old 03-25-2009, 12:14 PM
so i need to fix asap!!??
Old 03-25-2009, 12:37 PM
kawi600's Avatar
I certainly would. You could pop other gaskets. Im surprised your engine hasnt turned into an oil sieve.
A rebuild of the stock pump is usually fine. Replacements cost a bundle.
If vacuum is a problem none of your HVAC controls, 4wd or cruise controls will work properly.
Old 03-25-2009, 02:50 PM
I think my rear main seal is leaking a bit so it maybe to late.
Old 03-26-2009, 12:50 PM
I order this one this morning i think its the sameone. Hopefully it will fix it.
ohttp://www.genosgarage.com/prodinfo.asp?number=GOULD_VPRK_9602ne
Old 03-26-2009, 12:51 PM
Ok that didn't work like i planned
Ramdriver15
10-16-2007 09:07 AM
wildchild97
09-25-2007 02:44 PM
adidasman23
03-06-2007 09:05 PM
fearthedeere
02-09-2006 06:38 PM
Quick Reply: blowed gasket
