block heater...
It runs about 650 watts or something like that.
If you plug it in, make sure you unplug before you drive off (and don't ask me how I know that).
I usually wrap the cord around the mirror so I see it before I drive off.
Make sure you're using an HD ext. cord. It's 750 watts, unless someone upgraded it. It's stamped on the actual heating element if you wanna climb around the engine bay to figure it out. The element itself is mounted on the block just behind the oil filter and under the turbo. A PITA to get to, to be honest.
The cord should be dangling somewheres behing the passenger side head light. It should be zip tied to some wiring and a clip holding it to the front radiator support.
is there any advantage to using a blockheater/coolant pump that will circulate the coolant while it heats it up? I can get on at work for $26, but I didn't know if there was any advantage to it over my stock block heater.
I would think so...with a normal block heater it just heats the coolant in a small area around the heater. Circulating warm antifreeze throughout the block would be infinitely better.
The cord normally pops out at the radiator support (passenger side and runs down just behind the grill.
The heater alone will circulate the coolant, via natural convection (laws of thermodynamics). A pump would definitely help circulate the coolant better than natural convection/circulation. Would like to know more about this pump. Does it run on 12 Volts DC (truck power). If so then you will have to worry about battery drain.
J.R. they run on 120V AC: http://www.shop.com/Kat_39_s_1500_Wa...p!.shtml?trk=1
rjm022
Dec 11, 2019 09:17 PM
SpeedyWS6
15
Feb 2, 2011 07:22 PM
supersonictoys
Nov 8, 2008 09:17 PM
modiesel
Mar 7, 2008 10:44 AM
