Block Heater Run Time
Old 11-21-2004, 09:01 PM
triplenickel's Avatar
So I have a new job, however it's a camp job. I'm away from home for 2 weeks at a time where I park my truck near the airport has plug ins available, but they are not timed. Will it hurt to leave in plugged in for the whole time? I guess I could use a timer but the arrival of the flight home can vary by 3-4 hours. Maybe I should just put it on a timer from noon till 6:00 P.M. any thoughts?
Old 11-21-2004, 11:45 PM
Nevada's Avatar
Airports with available plug ins. Cool. I can't think of anything you would hurt by leaving it plugged in the whole time.
Old 11-22-2004, 12:15 AM
Cool is an understatement, this is the land of six months of winter!
Old 11-22-2004, 03:24 PM
Jeff in TD's Avatar
I would guess that the heating element ages as much by the number of heating and cooling cycles as by the total length of time it has been on.
I don't think you will hurt it by leaving it plugged in, plus the heater is not a super high cost item.
On the other hand, I don't think you would hurt the engine by starting it one time in cold weather when not plugged in...
Old 11-22-2004, 07:25 PM
I hear ya Jeff, but I'm more worried about getting home at -40° with wind than a little wear. What's the coldest these trucks are supposed to start without plugging in?
Old 11-23-2004, 08:59 AM
nirion's Avatar
I belive -20 F is the coldest temp without being supposed to plug in.
Nick
Old 11-23-2004, 11:17 AM
AKram's Avatar
No problem leaving it plugged in for an extended period of time. I do mine all the time.
Old 11-23-2004, 04:38 PM
AirGrabber's Avatar
leave it plugged in. Will not hurt a thing. Except the place where you plug it in will have a slightly higher electric bill
Old 11-23-2004, 05:35 PM
spudman's Avatar
i started my 99 at -38 before buy it was not real happy by it needed multiple grid cycles but if you can plug it in do it you get the added benefit of heat in the cab in reasonable time
Old 11-23-2004, 06:52 PM
Plugged in full time it is! Thanks gents.
rjm022
12-11-2019 09:17 PM
supersonictoys
11-08-2008 09:17 PM
modiesel
03-07-2008 10:44 AM
jswar
18
12-23-2007 12:18 PM
Reelay
12-01-2005 06:14 PM
Quick Reply: Block Heater Run Time
