BLAH - Need trailer wiring help
Old 05-16-2008, 03:36 PM
DTR question asker
dieselfuelonly's Avatar
I would REALLY appreciate it if someone has a diagram that they KNOW works for the 7-pin connector on a '96 Dodge Ram.
Heres what info I can provide:
Using a couple of diagrams I have at least found out which pin the right turn signal is for .
I can't get ANY of the other lights to work yet. I have a feeling the signal light doesn't work on the left side, but the running light does. I hooked the running lights wire up to the "right signal" connector that I do know works, and all of them flashed. However when I try to hook that wire up to the running lights connection according to the diagram, I get nothing. And who knows if the brakes are doing anything yet.
Its a 2006(?) Ponderosa 2 horse trailer. It has electric brakes on the rear axle, a battery break-away backup system, 2 rear tail light/brake light combo lights, and running lights. 5 wires run to the trailer, I'm trying to convert it from the stupid 5-pin connector that it came with to the 7-pin connector that the truck already has on it.
Thanks for any help, I'm just sitting here my brain trying to figure this out.
Old 05-16-2008, 05:00 PM
Devin_01's Avatar
You have good groungs on the truck?? I good way to tell in to get a booster cable and hook one side to the trailer and the other to the truck. T
Old 05-16-2008, 05:08 PM
DTR question asker
Well we rigged it up with the 5 pin adapter last night to get the trailer back home, just didn't have brakes on the trailer, and everything worked fine, so I think its got a good ground.
Feed Em
07-14-2012 08:14 AM
Krob
15
12-11-2007 01:05 AM
barngal6
05-31-2007 07:51 PM
Nevada
08-03-2004 05:48 AM
dsljunkie
05-11-2004 10:54 PM
Quick Reply: BLAH - Need trailer wiring help
