BigLine Install Help
Old 08-27-2011, 02:47 PM
Tejas TJ's Avatar
Question BigLine Install Help
I'm installing a BigLine kit from the filter to the injection pump on my '01 right now and diselautopower isn't open to help me out.
1. Do I reinstall the washers around the adapters that go into the pump and filter housing?
2. I had a fuel pressure sender with a tapped banjo bolt mounted at the injection pump. Do I reuse the tapped banjo bolt?
Old 08-27-2011, 03:50 PM
Tejas TJ's Avatar
Nevermind got it. Make sure when installing a bigline from the filter to the pump, I would leave the hose around 13" because if you cut it any shorter you won't be able to get the power steering fluid cap out. You also will run the 1/2" hose right next to the block which I'm assuming will heat the fuel going into the injection pump quit a bit.
Old 08-28-2011, 04:10 PM
KATOOM's Avatar
Since you cant or shouldn't use that tapped banjo anymore, you should have one of these. http://www.vulcanperformance.com/push-lock-p/poet8.htm
spooled142
03-19-2009 09:10 AM
UnrulyNFS
10-17-2006 08:57 PM
QWKRTNU
09-26-2006 10:22 PM
Mark Thomas
07-08-2004 08:01 PM
Quick Reply: BigLine Install Help
