Best rear end rebuild kit
Old 02-16-2007, 05:35 PM
Ramdriver15's Avatar
where is the best place to find a cone type locking rear end for my cummins? im pretty tired of those one wheel peels! I can definatly install this on my own just need to find a kit, and im not able to spend the money on eaton or such!
thanks
John
Old 02-16-2007, 10:14 PM
anyone ever had luck!!!
Old 02-18-2007, 12:59 AM
NMCTD's Avatar
if you have a dana70 you have lots of options, if you have a dana80 they are more limited, and if you have 3.54 gears even more limited. but here is a few links for you to check out
http://www.jawsgear.com/store/catalog/
http://www.ringpinion.com
http://www.accuautoparts.com/index.jsp
Old 02-18-2007, 08:54 AM
TxDiesel007's Avatar
thanks
John
If you are looking to do this on teh cheap
although i dont reccomend it for our trucks, you can lincoln lock the rear differential. If you arent gettin me, just weld the spider gears together and ud be good to go for a while... If you can find a detroit or a powertrax off of ebay that would work too
Rick
Old 02-18-2007, 09:12 AM
thanks, ive thought about welding the gears but id prefer not to. i have the 3:54 gears in the dana 70...
im looking to get something that will stop that one wheel pel because when im in the snow or muddy parking lots hunting, and when im launching the boat down that gravel ramp this thing tends to sink one wheel, and then i have to use 4x4 just to move the truck....
Old 02-18-2007, 02:12 PM
NMCTD's Avatar
I'd be kinda suprised if you have an open diff. You might check and see if your diff has the factory LSD, if it does then you probably could just order a trac-lock rebuild kit. They aren't the greatest, but it works ok
Old 02-18-2007, 06:57 PM
hmmm, mabe ill have to pull it apart and see whats in there, i have lsd im pretty confident i do because i can occasionally get a two wheels to spin if they break free at higher speeds....
Id definatly like to get a real good posi kit but i have so much going on
DodgeDiesel61
06-03-2008 07:50 PM
shecom3
25
10-19-2007 04:18 PM
doorguy
06-08-2007 06:19 AM
Ilikebikes
10-11-2006 07:56 PM
Dusty Ratcliff
10-03-2006 10:51 PM
Quick Reply: Best rear end rebuild kit
