BD's r700 twins
Old 12-27-2008, 01:09 PM
mulisha's Avatar
BD's r700 twins
anyone running this twin set up. i was trying to up my psi from 52psi to about 60psi. i dont know where the adjustment is.could someone show a picture or something. thanks.
Old 12-27-2008, 03:38 PM
O.T
O.T's Avatar
are you burning all the fuel you have?
Old 12-27-2008, 03:40 PM
mulisha's Avatar
not quite all, def have some room there.at least 8psi.
Old 12-27-2008, 03:55 PM
mikmaze's Avatar
not to mention you still have a few sw numbers to go........ and levels on the ez to add even more fuel that needs burning.
Old 12-27-2008, 05:45 PM
DUKCALN's Avatar
PM you on the other forum...... adjust the wastegate rod. Take the pin off of the end of the rod allowing the rod to extend. Adjust the amount of turns you need to get to 60psi, probley 6 turns. Take an air hose and insert into the wastegate and blow air into the wastegate to extend the rod. While the air is extending the rod reattach the rod with the pin. Take it for a test drive and repeat if needed to get the psi you want...Good luck
dodgediesel
ABDTR #5
10-18-2011 09:22 PM
dodgediesel
ABDTR #5
496
10-16-2011 04:33 PM
DUKCALN
04-10-2008 01:58 PM
kantdrive55
23
12-15-2007 05:00 PM
kantdrive55
19
10-26-2007 12:15 AM
Quick Reply: BD's r700 twins
