BD x monitor
Old 01-04-2010, 06:52 PM
Turbo-Dodge's Avatar
BD x monitor
Driving down the Highway last night, my BD x monitoring system shut down. It has yet to come back on. I've checked all my wiring and fuses and have found nothing. The System is bout 2 years old. Any ideas?
Old 01-04-2010, 08:26 PM
milesfelix's Avatar
I know this is going to sound redundant. My apologies if so, but I'd recommend going over the connections again. But this time look closer to the pins in your electrical connectors. There may be a pin that's bent just enough that isn't providing proper contact, thus resulting in no monitor. If you haven't found anything, then I'd suggest to clean out your grounds and power just to be on the safe side. I know that monitor is fairly pricey for what it does, so I don't want to see you toss it out.
Old 01-05-2010, 06:04 PM
Checked grounds an everything. All fuses in fuse boxes. Pins are all good and have a tight connection.
nitis
02-26-2007 07:38 PM
LinearX
03-21-2003 07:25 PM
hdsquirrel
03-19-2003 11:12 PM
kcjetchaser
12-02-2002 10:02 PM
Quick Reply: BD x monitor
