banjo bolt thread size???
Old 06-18-2007, 04:53 PM
ataboy9026's Avatar
Anyone know the thread size of the banjo bolt on the inlet of the CP3 pump? I was gonna make up a kit for a 2 micron filter and wanted to get some new bolts first and tap them for a guage. The ones from Geno's say 98.5 - 2003 24 valve. I assume that is not for a common rail.
Old 06-18-2007, 05:20 PM
Speed Shift's Avatar
It is a 12mm x 1.5thread. A o-ring type fitting will be the easiest to find.
SPEEDSHIFT
Old 06-18-2007, 05:42 PM
tristan21's Avatar
Anyone drilled there banjo on here? I was wondering what size to do? I couldnt seem to find the write-up on that one today. I dont know if the fass system is already as big as you can go cause I didnt get to install that one
Old 06-18-2007, 09:00 PM
8mpg's Avatar
I put a write up in your other thread about the fuel vent mod... The write up has info on tapping the banjo bolt...
Old 06-18-2007, 09:04 PM
8mpg's Avatar
you can tap the stock bolts for a gauge. Here is the write up I did on a gauge install but I tapped the stock cp3 bolt.
http://rapidshare.com/files/37993612...stall.doc.html
Tommy93w350
11-16-2016 06:40 AM
8mpg
06-15-2007 07:38 PM
Pinkston
04-04-2006 07:46 AM
CapnRam
06-20-2005 11:00 PM
Quick Reply: banjo bolt thread size???
