banjo bolt thread size???
Anyone know the thread size of the banjo bolt on the inlet of the CP3 pump? I was gonna make up a kit for a 2 micron filter and wanted to get some new bolts first and tap them for a guage. The ones from Geno's say 98.5 - 2003 24 valve. I assume that is not for a common rail.
It is a 12mm x 1.5thread. A o-ring type fitting will be the easiest to find.
SPEEDSHIFT |
Anyone drilled there banjo on here? I was wondering what size to do? I couldnt seem to find the write-up on that one today. I dont know if the fass system is already as big as you can go cause I didnt get to install that one
Originally Posted by tristan21
(Post 1559399)
Originally Posted by ataboy9026
(Post 1559337)
http://rapidshare.com/files/37993612...stall.doc.html |
