axle splines
Old 10-12-2005, 09:11 PM
rattlbox's Avatar
axle splines
how many axle splines are on a 2001 with a dana 80
Old 10-12-2005, 09:33 PM
newriverSpecon's Avatar
35
Randy
Old 10-12-2005, 09:41 PM
Clunk's Avatar
The '01 service manual doesn't say but removing a rear hubcap then removing the axle bolts from the rear wheel hub, you can pull an axle without taking off the rear wheel or jacking up the truck and count the splines easily. Safety hubs are neat.
Old 10-13-2005, 06:16 AM
CTD NUT's Avatar
Not much point removing the axle shaft to count splines.....the D80 in Dodges were only ever offered with 1.5" 35 spline shafts as Newriverspecon mentioned. There were larger D80 OEM shafts but only on some medium duty trucks - never in a Dodge.
Old 10-13-2005, 11:11 AM
ridofpwrstroke's Avatar
The NUT is right. I just put in an ARB locker and changed the gears to 4.10's and the 80 only came with a 35 spline 1.5" shaft. No need to tear apart your truck. We wouldnt lie to you.
Old 10-13-2005, 11:38 AM
CTD NUT's Avatar
dieselcarpenter
01-26-2008 09:33 PM
Bookshelf
07-02-2007 01:29 PM
Leadfoot
11-29-2005 06:45 PM
Stamey
07-24-2003 04:42 PM
Quick Reply: axle splines
