axle paint???
Old 10-13-2006, 07:29 PM
2006 MEGACAB's Avatar
axle paint???
I noticed this morning when looking at my truck go down the road the black paint is coming off the axle anyone elese having this problem seems kinda odd for a 8 month old truck. Thanks Rob
Old 10-13-2006, 08:12 PM
socal 610's Avatar
mine look like there 10 years old,but not even a year old I am going to get a nice looking rearend cover to make it look good again
Old 10-13-2006, 08:27 PM
burlhall's Avatar
The paint is peeling on mine as well. Guess the next time I change the gear oil I will sand it and give it a good paint job. Guess the factory could use some paint lessons.
03whitedually's Avatar
use some degreaser to clean then paint gloss black spray paint $.99 fix
Old 10-13-2006, 08:37 PM
Puddlestomper's Avatar
Go to your local parts store, and get the spray on bed liner in a can. 5.99, and will last forever. Plus it won't scratch.
Old 10-13-2006, 08:55 PM
Hairtrigger's Avatar
Won't that hold heat in?
Old 10-13-2006, 09:16 PM
glad to see everyone else is having the same problem..
Old 10-13-2006, 09:22 PM
pullin hard's Avatar
yup, mine doingit too, but have almost 240,000kms on it, just started to rust and pit.
wire wheel it, and then use por15 black paint, you will never paint again, and you can smash in to things and it won't chip or rust.
Old 10-13-2006, 10:10 PM
Allen Hibbs's Avatar
Por15 makes some great stuff. Im considering using this when mine starts to peel and chip http://www.por15.com/PRODUCTS/PRIMER...8/Default.aspx
Old 10-13-2006, 10:34 PM
maybe get it powder coated???
Old 10-14-2006, 07:40 AM
Hemi Dart's Avatar
Exclamation
I painted my front suspension & differential w/ POR15 about 5 years ago. It all flaked off within 3-4 years. Followed the directions to the letter (etching fluid, left surface rust for "teeth" ect.). Not mad. Road salt is a brutal environment for any product to stand up to.
Eastwoods Rust Encapsulator has much better reviews than POR15.
Old 10-14-2006, 09:13 AM
rjm022's Avatar
my looks brand new-(as does the whole under side of the truck!) truck has 52,000 miles on her . i has been through twp western, ny winters also- but i get my truck sprayed yearly!
http://www.carwell.com/
mullishacrew
03-19-2012 09:05 PM
easinc
03-16-2011 03:25 PM
lovin1stgens
10-30-2010 12:33 AM
st.rodder2
23
12-17-2008 10:47 AM
RJOS
05-27-2007 10:19 PM
Quick Reply: axle paint???
