Aux Fuel Tank and Truck Cap
Old 01-10-2010, 01:59 AM
Hutch's Avatar
Is it possible to run an Aux Fuel Tank inside a Truck Cap?
I'm concerned about safety ie, venting in the cap.
What are my options?
Hutch
Old 01-10-2010, 02:12 AM
ofcmarc's Avatar
Remote mount the vent.
Old 01-10-2010, 05:45 AM
MoparMarv's Avatar
I have a 110 gal bed tank and I have been thinking about putting my cap back on. My venting cap always makes a mess when the tank is full other than that its dry. Unless I were going to sleep back there, carry an animal or be running a camp stove or heater( not that I would anyways next to a fuel tank) I would not worry about it. My tank is a transfer tank so its limited to venting options unless you want to make something custom. However i see your in AZ so the heat may cause issues that I don't have.
Old 01-10-2010, 07:40 AM
Bob Beauchaine's Avatar
I've got a 45 gallon aux tank inside my truck cap. It is plumbed so it can be filled from the same side as the main tank. I went to a junk yard and got a cut out section from the side of a wrecked gasser so I could plumb through the side of the cap. I plumbed the fuel feed and return line through two manual selection valves on the floor next to the drivers seat so I can switch tanks on the fly. I also ran the fuel guage through a SPDT electrical switch so I can read the fuel quantity in the tank I am using, The system works great.
Bob
Old 01-10-2010, 08:26 AM
Boatnik's Avatar
Hutch
If you want to install a remote vent, you can get a vent from a marine hardware store or even Walmart in some areas. The vents are designed with a screen to prevent flash fires and fit to a 5/8 inch neoprene hose. A hose barb in the existing tank vent connection should complete the installation. The vent needs to be higher than the top of the tank to prevent spills.
Old 01-10-2010, 07:55 PM
JustRamIt91's Avatar
I wish i could find pictures. My boss's truck has a 110gal gas tank in the back of his capped truck. He leaves the windows open and has it plumbed up to about 2' above the bed rail and it uses a standard gas cap with aluminum flip cover. If you don't have side windows you could probably make some vents in the highest point with a cut off wheel.
Old 01-10-2010, 10:23 PM
Hutch's Avatar
So it is possible.....thanx for the replies.
Hutch
silver_2000_tj
10-02-2009 04:31 PM
PRO-NRA
16
04-01-2008 12:13 PM
ramsport59
MDDTR #33
02-21-2008 04:15 PM
groran
03-19-2007 07:44 PM
2500CTD
02-27-2005 01:29 AM
Quick Reply: Aux Fuel Tank and Truck Cap
