Automatic Trans Questions
Old 01-04-2008, 09:21 AM
deking1970's Avatar
Hey Guys,
My Dad just bought a '98 4x4 dually with a 12 valve motor and automatic transmission. Both of us have owned Cummins trucks for several years now, but never an auto. Anyhow he is telling me that the truck seems to kick out of gear going down hills (rpms drop and it seems like the truck is coasting). Is this normal? Also the transfer case sometimes kicks out of 4wd on the first try, but if you put it back it stays. Should I check the linkage or could this be internal?
Old 01-04-2008, 11:18 AM
Mcmopar's Avatar
If you completely "lift" your foot, the TC unlocks and it does "freewheel". About the t-case, I would pull it into 4 wheel then hold the lever for a second or two while moving forward and see if that helps.
samiam4
01-24-2015 07:54 PM
Ghostrider
12-24-2011 12:22 PM
TE-44
04-27-2004 05:09 PM
pappygtb
05-31-2003 12:37 AM
TPilaske
01-28-2003 10:47 AM
Quick Reply: Automatic Trans Questions
