arp studs
Old 04-02-2009, 03:26 PM
DTanklage's Avatar
arp studs
anyone know what is the difference between the 247-4202 and the 247-4203 stud kits
one is supposedly for a 1st gen and the other for a 2nd gen but i dont see what would be different
thanks in advance
don
*i have the 4203 kit and a 2nd gen truck
Old 04-02-2009, 04:01 PM
kennyblatz's Avatar
94-98 4203
98-02 4202
um i guess i don't have the anserw to your question but the studs are different from a 12-24 valve motor in what way im not sure
Old 04-02-2009, 06:18 PM
DTanklage's Avatar
these are both 12v motors
and i cant see there being any difference in the two set of studs
Old 04-02-2009, 07:25 PM
oaborbag's Avatar
a 24v stud kit has all the same length studs except for the 6 outside the valve cover, a 12v kit has a different length stud every other set, I don't have a 12v so I do not know why they are different length, but I know that is the difference in the two sets. But a 247-4202 is definitely not for a 12v or a 1st gen.
Old 04-03-2009, 07:40 AM
Jetpilot's Avatar
The 247-4202 is for the 24v engine and the 247-4203 is for a 12v engine. These engines have different stud length requirements due to the differences in the heads......
Old 04-03-2009, 12:54 PM
Ronco95's Avatar
The 12V has a pedestal mounted set of rocker arms and therefore has one long bolt per cylinder.
The 24V does not have a similar setup.
Old 04-03-2009, 02:16 PM
DTanklage's Avatar
wait - i thought the 4202 was for the 12v p-pump motors
no?
(not concerned with 24v studs)
Old 04-03-2009, 02:47 PM
1320's Avatar
247-4202 is for the 98.5 - 2002 24 valve engine.
247-4203 is for 89-98 12 valve engines.
I believe the "new" 4203's require machining the rocker boss down .200 where as the original 12 valve studs did not but some hit the valve cover and caused sealing issues with the cover. So the fix was to shorten the stud which requires the rocker boss to be machined down.
Old 04-03-2009, 03:12 PM
DTanklage's Avatar
and thats what i have...
the ones that do req machining the stand down 200 thou
good to go
thanks
Old 04-03-2009, 09:18 PM
Tate's Avatar
Just doesn't make sense to me to take a situation that your average DIYer could fix (remove the ribs in the valve covers) to having to now find a machinist (or atleast a mill) to remove .200 from the pedestal. Oh well.
Don M
32
05-12-2006 02:37 PM
James Lucas
06-13-2005 08:46 PM
AK RAM
15
04-05-2005 11:25 PM
BARTMAN
03-24-2005 04:59 PM
jermey1980
27
02-27-2005 06:11 PM
Quick Reply: arp studs
