apps problems
Old 01-29-2007, 06:34 PM
dieseldork's Avatar
Cool apps problems
After Recalibrating And Restting My Apps I Did Both Know My Brake Light And Abs Light Stays On . Can Anyone Shed Some Light On This?
Old 02-03-2007, 11:30 AM
jigdog's Avatar
any thing besides that
I have had apps problems,meaning it unlocked the converter when i was at 40-45 mph and sometimes would kick out of overdrive at 60 + ?. it as very consistently inconsistent. mine didn't have the air bag lights etc. What codes do you have. if it is an apps problem it will have a code. Do you know how to see if there is a code in the system?
Old 02-03-2007, 10:32 PM
dieseldork's Avatar
Well Sense I First Posted This I Checked My Codes And Kown Of Them Had Anything To Do With The Lights That Were O And Know My Lights Have Went Out . So I Don't Know What The Problem Is Or If There Even Is One.
Old 02-05-2007, 02:27 AM
shawn085's Avatar
I just changed my apps and there was know code. The throttle was hunting of had dead spots, but cruise worked great. Figured it had to be the apps and it was.So know code doesn't mean there isn't something wrong. I don't know if I have this right or not but the ABS computer is seperate from the truck computer. If you have a ABS light you can try pulling the fuse for 30sec and reinstall to reset ABS computer. If the light is still comeing on then it soundes like you have a ABS problem. Search and you can find lots of info on here. In order to scan the ABS computer for codes you need a DRB 3 scan tool. ABS codes will not come up in the odometer window. And know the smarty can't scan this either
hamilton71801
12-02-2007 07:32 PM
dieseldork
01-29-2007 11:32 PM
buckaroo98
09-09-2006 07:18 PM
bama
0
02-21-2005 07:27 PM
dkingcan
02-17-2005 01:49 PM
Quick Reply: apps problems
