Any point in upgrading injectors?
Old 06-03-2010, 09:29 PM
1882's Avatar
With the mods I have in my sig would I benefit from going to a higher quality injector like Machs? I already hit 45 psi quite easily and that's really the little BD's limit isn't it? Thanks!
Old 06-03-2010, 09:41 PM
8UPRACIN's Avatar
Throw a S475 under that Super B with some Mach 5's and let her rip! I really like my Mach 7s. They are less smokey and cooler than my Edge Jammer 5s but I liked them too till I got the big ones. If you do bigger injectors you might wanta look into a Billet Input at least plus some studs. Good start build for sure man!! Good luck with the choices
Old 06-03-2010, 10:22 PM
PowrStorkthsRam's Avatar
1882, i am looking at new inkectors also but the budget is a little snug with my first kid on the way. How have the jammer nozzles worked for you? and if you do end up getting new ones, would you be interested in selling the jammers?
Old 06-04-2010, 07:48 PM
1882's Avatar
well, i have the whole injectors, not just the nozzles. they seem to do ok, i never really get too hot, even with the edge and smarty turned up. just wondering if there is any more performance to be had with the higher quality mach. i can't really take any more boost and egt's aren't an issue so is the upgrade worthwhile? if i do get the mach's i would definitely sell the jammers.
jobanglez920
04-16-2015 10:00 AM
bngcustoms
07-17-2009 04:53 PM
booger50
07-20-2008 11:41 AM
Bulldozer
02-24-2003 05:16 PM
Quick Reply: Any point in upgrading injectors?
