Another interior question (Removing faux wood)
Old 10-16-2006, 01:08 PM
RAW
RAW's Avatar
Does anyone know if the faux wood panels on the dash and doors can be swapped out?
I know on my 03 trucks that the wood panel plastic was "welded" to the back of the dash and door panels, making it impossible to swap out.
I would just prefer the black or silver inserts.
Old 10-16-2006, 01:22 PM
subspd's Avatar
I know the center section on the dash is all one huge piece and you cant change just the wood there... However you could remove the section and then have the wood painted high gloss black or silver or something. But then that leaves the wood on the doors??? As far as I can tell they are superglued on. Ebay has some guys selling covers/replacements but it it all big $$$ 300+ if I remember right. I would like a way to safely remove the door sections and have it all painted high gloss black... just my 0.02
Old 10-16-2006, 03:12 PM
Shanajustin's Avatar
Mine are now silver hammertone Rustoleum. Trust me, if you dislike the fake wood, anything is better than THIS fake wood. You'll be happy you did it. I didn't understand this move from Dodge. Fake wood didn't work 20 and 30 yrs ago, why would they think that it would work now?
Old 10-16-2006, 04:20 PM
carcrz's Avatar
I'm actually wanting to go the other way. I added some carbon fiber & it is already coming off because I did it in the winter time & it was too cold out.
Old 10-17-2006, 01:12 PM
subspd's Avatar
So how did you remove the door panels?
Old 10-17-2006, 09:04 PM
skipro3's Avatar
Door panels are easy to remove.
Take the phillips screw out at the piller; up by the mirror/window post.
Take the handle off. It's a Torx but I can't remember the size.
Take the 2 screws off a the very bottom of the panel.
Lift up on the door panel. It is held on with several tabs that fit into slots in the door. If you just try to pry it off, you will break the tabs.
Lift high enough to clear the door lock or unscrew the door lock **** first.
As you take it off, unplug the wiring harness for the window/doorlocks.
This is fairly easy to do..... since I could figure it out.
Good luck!!
Old 10-18-2006, 03:59 PM
subspd's Avatar
THANKS! And do the wood inserts come apart seperate or are they glued on?
Old 10-18-2006, 04:10 PM
cja
cja's Avatar
Check out some dash kit options...http://www.mimousa.com/home.asp?dir=products&prod=136
Old 10-18-2006, 06:50 PM
RAW
RAW's Avatar
If they're anything like the 2003 (and I imagine they are), the wood-plastic parts have tabs that insert into the rest of the panel. Those tabs are then melted to "weld" the panels together.
I wish they wouldn't do that.
Old 10-18-2006, 07:34 PM
subspd's Avatar
crap... thats what i thought as well.
seal20
32
06-18-2007 10:21 PM
jj3500
02-20-2006 01:27 PM
Vintage Empire
12-20-2005 10:02 AM
Quick Reply: Another interior question (Removing faux wood)
