Airdog fuel system
Old Jun 11, 2012 | 10:44 PM
td3620's Avatar
Question Airdog fuel system
i bought this very clean 01 dodge diesel,he put an air dog fuel system on it.well i hear nothing but good things,but im having problems with it.I got to 1/2 a tank of diesel and it was sucking air,and i was on a slight hill,,but the first week i had it,i got to a 1/4 of a tank until i had to get diesel.do i need new fuel filters,Please Help me thank you.since air dog cant answer me back.
Old Jun 11, 2012 | 11:41 PM
JARHEAD's Avatar
I feel your pain. Does it have a draw straw V on it? Someone had posted not long ago that the clamps used on the DSV tubing inside the tank sometimes dont do good enough and some guys have had problems with sucking air when about 1/2 tank or less.
Old Jun 12, 2012 | 04:17 PM
td3620's Avatar
i dont know.what to look for.where do i find it
Old Jun 12, 2012 | 04:59 PM
JARHEAD's Avatar
It is inside your tank. That is one possibility.
Old Jun 12, 2012 | 05:01 PM
JARHEAD's Avatar
No way to check that without dropping the tank. Maybe someone else will have some better advice to add.
Old Jun 12, 2012 | 05:38 PM
dkenny's Avatar
1/4 or 1/2 tank as measured by the gauge?
is the gauge right?
-dkenny
Old Jun 13, 2012 | 05:02 PM
td3620's Avatar
yes the gauge is right, and first day i got it got to 1/4 of a tank and i had to find gas station,now when i get to a 1/2 a tank it starts to suck air when i try to start it.i have to put pedal to floor to get it started
Old Jun 14, 2012 | 08:34 PM
dkenny's Avatar
I ask only because these truck have a know problem with the fuel sender..
I should have taken a picture on mine this am..read 'E' and the light was on..but when I turned it off the night before it was just under 1/2...
so is the gauge right?
at lunch today it was reading just under 1/2 tank..I didn't touch anything..just drove..
so is the gauge right??
did you measure the level in the tank manually? why did the problem level change from 1/4 to 1/2 tank? or is the gauge not reading right?
so when it start to suck air how much to put in the tank? 15 gallon or 34?
-dkenny
Old Jun 14, 2012 | 08:41 PM
HOHN's Avatar
My fuel sender has been failed for about 6 years.
Given the high cost of replacement and the likelihood of another failure, I just decided that a trip odometer was a useful substitute.
Old Jun 17, 2012 | 10:21 PM
td3620's Avatar
yes my gauge is right.it works fine.
Old Jun 23, 2012 | 12:14 PM
duster75's Avatar
take fuel line off and verify your problem by cycling key to start pump. Look at top of tank and verify that your fittings are not crackedor leaking. Keep truck 3/4 full so it cant suck air. I'm betting its the fittings on top of your tank. Its a push in to pull line off type deal and the steel "neck" gets rusty and fails....thats why I installed a draw straw and new sending unit as mine was off also.And when installing a straw you have too make sure your staw is cut to length and not too short. I did mine in trk lifted bed off.
Old Jun 28, 2012 | 05:08 PM
td3620's Avatar
thank you
01blackspeeper
Mar 23, 2012 04:52 PM
Tractor Truck
Jan 20, 2011 01:56 AM
kdbvulcan
20
Dec 6, 2008 04:34 PM
jentas
33
Mar 7, 2008 02:45 PM
vp_mopar
33
Jan 28, 2008 06:35 AM
