Air dog on a 2003 Easy or Hard?
Old 01-25-2008, 06:17 PM
3592788's Avatar
Question Air dog on a 2003 Easy or Hard?
I was wondering if i put a airdog 100 or 150 is it very hard to do on my 2003. Do i have to make any holes in the tank? Do i have to drop the tank? Thanks for any help
Old 01-25-2008, 06:21 PM
cincydiesel's Avatar
There is a good write up on this that was posted a while back. Try doing a post search. It looked pretty hard to me, then again I'm no machanic
Old 01-25-2008, 06:32 PM
3592788's Avatar
I think i seen one done on a 2006 and i was wondering if it was the same or did they change from the 03-04s to the newer ones?
Old 01-25-2008, 06:35 PM
cbrahs's Avatar
do a search for 53willy's write up. he did a great write up and may answer your questions
I would think it changed due to the 04.5 changed to CR's
Old 01-25-2008, 06:37 PM
Luvnacumns's Avatar
https://www.dieseltruckresource.com/...airdog+install
Old 01-25-2008, 06:39 PM
DiEseLjunKy's Avatar
*****'s is the 150 install, this guy did a 100 install and writeup with pics etc: https://www.dieseltruckresource.com/...d.php?t=185809
Old 01-25-2008, 06:51 PM
rip 112's Avatar
03 was the beginning of the HPCR fuel system.
Old 01-25-2008, 06:58 PM
3592788's Avatar
Ok so if i were going to do it i could ecpect to do the same thing as ******? Thanks very much
Old 01-25-2008, 07:03 PM
53 willys's Avatar
the only difference is the 03-04.5's have the plug & play harness...if you get a AD100 then you don't have to cut a hole in the tank....if you get a AD150 you do have to cut a hole or you can try the jeep canister...If your truck has had the intank LP conversion and you want to run a AD100 then you have to bypass the intank pump. if you want to hook up to the stock pick-up...the AD100 is good to around 550hp.they are easy to install either way IMHO....clear as mud???
Old 01-25-2008, 07:12 PM
3592788's Avatar
Ok so all i want to do is be able to run my juice on hot and mabey a programer. So would you reccomed the 100 or 150? The tank and everyting is stock. I just want a good relaible system. Thanks
Old 01-25-2008, 07:13 PM
53 willys's Avatar
if you dont plan to go over 550hp then get the AD100.....my.02
Old 01-25-2008, 07:14 PM
rip 112's Avatar
I'll be going with the 100, seems like more than enough for you also.
Old 01-25-2008, 07:21 PM
3592788's Avatar
Allrighty thanks for all the help so fast. So if i get the 100 i dont need to make any holes in the tank i just use the existing stuff. Thnaks
Old 01-25-2008, 07:25 PM
53 willys's Avatar
yep...and if you still have the filter mounted pump you may get away with out having to drop the tank or lift the bed??? I have not tried a install like that but you might get lucky?? you might be able to reach in from the rear fender well and access the top of the tank....
Quick Reply: Air dog on a 2003 Easy or Hard?
