Adjusting wastegate on a 00'
Old Sep 14, 2008 | 07:26 AM
Hothead2500's Avatar
How do I adjust the waste gate on my 00'? I dont see a nut on the rod that I can turn. Do I have to take the whole waste gate off and turn the one end of it. Or is there any easier solution to create more boost.
Old Sep 14, 2008 | 11:38 AM
gwirehair's Avatar
plug it!!
Old Sep 14, 2008 | 12:20 PM
bob4x4's Avatar
There are fittings available that have a restrictor and bleed off hole that will take all of 5 minutes to install.check it out here
http://www.turbodieselregister.com/c...uery=retrieval
Bob
Old Sep 15, 2008 | 05:25 PM
quads4_life's Avatar
can you get a boost elbo like that at a local auto parts stor?
Old Sep 15, 2008 | 10:20 PM
jrs_dodge_diesel's Avatar
Not likely that you would ever find something like that at a Napa store.
Another thing I just thought of. Even if you put in an elbow, you would not see any benefits without a boost fooler for the ECM. Without the fooler, the ECM will cut back on the fuel to keep the boost pressure down.
Old Sep 16, 2008 | 02:46 AM
opiy2k's Avatar
if you just un-bolt the head it does twist i dont know the difference between automatic and standard trannys just the position. but i would use the adjustable elbow or make your own it cost me $7 at the hardware store and as long as you have a programer or chip you dont need a boost fooler. a boost fooler is just fun for a little extra smoke
hillbillymudrun
Jan 19, 2007 10:38 PM
wana12v
0
Aug 15, 2006 04:16 PM
fishin fever
Apr 23, 2006 10:55 PM
CTD_Neil
13
Sep 22, 2005 03:22 PM
GatorRam
Oct 12, 2003 09:05 PM
