Acetone Works for Me
Acetone at the ratio of 1.8 oz per Ten gallons #2 diesel has given me average of 5% increase in fuel economy. Acetone cleans up the smoke, especially if you run red dyed fuel. I have noticed that my cold weather start ups take much less cranking when I have acetone in the tank. I actually make a little more boost, 1-2 psi increase. Acetone, however, only seems to help in colder weather. In the hot summer months, It seems to make little difference on Start Up, Boost, and MPG.
acetone is going to thin out your fuel really not a good idea
...... you need to be adding lubricity to your fuel otherwise your gonna kill your fuel system FAST
..... especially now that we have to run the junky ULSD you really ought to be running a lubricant additive (2 cycle ashless tcw3 oil)to your fuel rather than taking it away.... i dont care how much fuel mileage you increase its not worth it.......
that VP44 of yours is about the most sensitive piece of equipment out there and taking lubrication away from it has to be the worst thing in the world....... its like running straight gas in a chainsaw rather than mixed....... yeah it might run like a raped ape, until it all takes a big crap on ya.....
better have a thick wallet if your running off road in your truck!!!, just had a customer get busted runing it a month ago, hes finding out it wasnt worth it!
TDR ISSUE 52 Page 154
Mike
the fellow talkin about it costing you money to run this is referring to the off road (red) diesel, not the acetone. although both could get expensive. my dads buddy keeps his stock fuel tank filled with green (road) fuel, but his in the bed aux. fill tank full of red. guess which one his motor draws from? hint- he doesn't buy a lot of the green. all the plumbing is well hidden, and has done this on old ford diesels for years. yeah, you can check the tank, sir.
this is also what I used to do in my old 6.9 and my 7.3 fords when I was rodeoing in high school!,, but nowadays, you better believe they are gonna check your truck out head to toe!!!, if they want to get real jerky on you, they can ask to pull fuel right from your line on your fuel filter, or injectors..... NO KIDDING!!!,
Im just thinking this is a not good idea!!
hew was checked years ago, but they just stuck a rod with a little cloth on it down his stock fuel tank. i belive it was DOT. he owns an excavation outfit, and they hassle him from time to time.
RockRover
18
Apr 14, 2005 12:56 AM
MST
Jul 7, 2004 02:00 PM
dss667
Mar 17, 2004 05:42 AM
