ABS Issue
Old Jun 7, 2012 | 06:51 PM
DeTree's Avatar
ABS Issue
I replaced the abs hydraulic Control on my truck and I think I messed up the lines that come out of it. There are 3, 1 left front, 1 right front and the 3rd to the rear. They all go down the left side by the wheel well. Does anyone know where I can find a diagram of which is which?
2002 3500 4x4 with 4 wheel abs.
Old Jun 7, 2012 | 06:53 PM
DeTree's Avatar
Quick update, when I stand on the brake pedal, the rear locks up.
Old Jun 8, 2012 | 07:17 AM
DeTree's Avatar
bump
Old Jun 8, 2012 | 06:09 PM
patdaly's Avatar
Thought the service manual had something, but it doesn't. Here is a printout from the parts manual, not much better, but you might be able to figure something out.
Old Jun 10, 2012 | 08:06 AM
DeTree's Avatar
Thanks, I got the lines straightened out, bought new from dealer. They only go in one way. Problem now is the rears are locking up under hard braking and it does not seem like the fronts are working right. ABS light comes on after hard braking (abs not activating), no codes and light clears on a restart. I am thinking possibly the combination valve or master?
Old Apr 30, 2013 | 08:00 PM
mtdoragary's Avatar
I'm watching. My right rear locks up under light braking and ABS does nothing.
Old May 1, 2013 | 12:53 AM
joem's Avatar
when I put my disk rear axle onto my old 1995 I was super worried about one wheel lockup as the sensor is on the ring gear- so as long as one rear tire is spinning the abs thinks all is good... lucky for me my abs sensor dropped right into the new 2002 axle and is performing perfectly.
Old May 1, 2013 | 08:20 AM
patdaly's Avatar
That's a specific brake issue at the wheel, as has been said, the rears are a single channel, so your ABS doesn't even see 1 side locking up without the other.
fitzydog
21
Oct 11, 2017 12:09 PM
DodgeRam24V
0
Jan 7, 2012 06:02 PM
BigBore050
Mar 9, 2010 11:46 PM
sssmaly
Jul 13, 2007 12:57 PM
mr T
Feb 24, 2007 06:42 AM
